HELP!!! Rear Turn signal question
Old Apr 10, 2009 | 03:27 PM
dugan's Avatar
dugan
Default HELP!!! Rear Turn signal question
I did a search and found no direct answer. I need to replace my rear turn signal (thanks Mother Nature). Will I need to remove that strut completely? And if so what wrench do I use? I have read where those stock bolts on the struts are a bitch to remove. any insight or tips would be great. I have the docking hardware on the rear turn signal if that matters
Old Apr 10, 2009 | 03:37 PM
ngoti8tor's Avatar
ngoti8tor
On my 2008 Fatboy, I removed the rear signals with a bolt from the inside of the fender. I didn't have to remove any strut bolts.
Also, later on I replaced my strut bolts with chromed bolts. They were tight, but I didn't have any problem with them.
Old Apr 10, 2009 | 04:05 PM
RockyTopRider's Avatar
RockyTopRider
I have done it both ways (removing and not removing the struts). imho it's not a big deal to remove the struts and makes installing the turn signals a lot easier. The strut bolts do have locktight on them, but they ain't that bad. Use a heat gun or soldering to heat them up and break them loose.
Old Apr 10, 2009 | 11:29 PM
malo's Avatar
malo
I changed the rear signals on my 07 fxst. without removing the struts. Piece of cake. You will be suprised how easy it is.
Old Apr 11, 2009 | 07:23 AM
tk353's Avatar
tk353
there is a thread in the forum about this on an 07 and a video. if i remember right you have to loosen the strut to get to the back of the bolt on the 07. if you cant feel it you cant remove it.
tcabello
Jul 4, 2012 11:48 AM
Pat C
Aug 20, 2011 10:04 AM
Mahoney
Aug 21, 2008 05:03 AM
wiz240
Jul 19, 2008 03:32 PM
Diablo Rojo
May 19, 2006 09:44 PM
