Hey Guys,
I've got a 2005 Fatboy and I recently purchased a Screaming Eagle seat that can be used as a solo seat with a chrome tailpiece over the fender or add the passenger pillion for 2 up riding. I purchased this seat from an individual on eBay for a good price ( these things are about $1000 form the stealer). Here's the problem; the seat and passenger pillion fit fine but when I try to out the tailpiece on the bracket doesn't line up under the seat and the mounting hole does not line up with the hole in the fender (it's about 1" too far back)?
It seems like I read about this somewhere a long time ago before I had this style seat. Anybody got ideas?
As always, thanks for the response!
I wolud agree if not for the fact that the passenger pillion fits fine. The holes in the bracket lines up with the studs in the seat and the rear mounting hole lines up with the hole in the fender. It's alomst like this is the wrong tailpiece but as far as I can tell they should be the same. I think they only put these seats on 05 and 06 Fatboys according to what I've found so far these models are the same?
Maybe you just need to tweak it a little. I am a bit unclear on what doesn't line up. Post some pics so we can actually see what yoau re talking about.
I purchased a large two-up off a fatboy? for my nightrain for roadtrips. When i first tried to install it, I thought the rear hold was off an inch but it turned out I was not seating the front tab into the mount by the gas tank correctly. I have to "flex" the seat a little and push down hard on the front before pushing the seat forward and it goes up much further and allows me to get that screw into the back tab hole.
probaly have to drill it. only made for the screaming eagle model. you can get a diamondback seat. for a regualer fatboy for under 2oo bucks. I have one for my 06 fatboy.
The bracket on the chrome tailpiece doesn't line up with the studs on the seat either. I'm wondering if there is a difference between a 2005 Fatboy and a 2006 Fatboy and if I have a 2005 seat and a 2006 chrome tailpiece? Something isn't right.
