SE A/C assembly
Old Apr 17, 2009 | 09:53 AM
SD Night Train's Avatar
SD Night Train
Default SE A/C assembly
After I put the new backplate and filter on I thought that I should have probably put some gasket butter between the gasket and backplate and gasket and intake....opinions?
Old Apr 17, 2009 | 10:00 AM
Damage_Inc's Avatar
Damage_Inc
I didn't put any on mine simply because the factory gasket didn't look like it had any. So far so good.
Old Apr 17, 2009 | 10:04 AM
DECON BLUE's Avatar
DECON BLUE
Thumbs down
None needed.
Old Apr 17, 2009 | 12:24 PM
SD Night Train
will it hurt anything to be running stock pipes with the SE backplate and K&N filter?
Old Apr 17, 2009 | 07:21 PM
Blk and Chrome's Avatar
Blk and Chrome
The gasket goes on dry, I would think that the ECM will adjust for the change. I'm sure the answers will go both ways here, fuel management or not.
Old Apr 17, 2009 | 09:53 PM
crazybastid83's Avatar
crazybastid83
Your bike will be too lean w/o some form of fuel management
Old Apr 17, 2009 | 10:29 PM
JR Ryder's Avatar
JR Ryder
There is a "suck" and a "push" with a motor.... if you haven't opened up the exhaust, but have just changed the filter, I don't think you'll need any form of fuel management. Only a dyno which can show volumetric efficiency, timing, & air/fuel ratio in a "before-and-after-mods" scenario would answer that question perfectly.
Old Apr 22, 2009 | 02:10 PM
SD Night Train
does anyone know how hard the connections on the SE kit are supposed to be torqued?
xdanman
May 31, 2010 12:38 AM
mjaw
EVO
Sep 28, 2009 08:31 PM
tbrenan
Mar 30, 2009 01:38 PM
radridd
Feb 29, 2008 09:03 PM
anubisss
Sep 4, 2007 03:37 PM
