TC 96 to EVO engine swap?
Old Apr 30, 2009 | 12:21 PM
  #31
howolf's Avatar
howolf
Originally Posted by Archer1968
My current setup is fine, but if i go the route with the SE204 then im on my own, when i spoke with him about 2 weeks ago he didn't have a map for my setup (SE stage I, Samson baloneys, PCIII) plus the SE204 cams on an 07 FXST. Ever since i heard that bike i spoke of before, its on my mind.
Yeah Archer, looks like that bike made quite an impression on you! ...I can even feel your enthusiasm up to here and it's working contagius man: I'm totally excited about this cam swap too!
So, will be the same problem here then (currently K&N, Rush 2", PCIII). I think i'll call the people at PowerCommander (next week though) to see if they have some answer, and if not then i'll probably put a post here on the forum somewhere to see if someone has the map.
To be continued...
Old Apr 30, 2009 | 01:42 PM
  #32
coop57's Avatar
coop57
Originally Posted by howolf
Thanks Grimm, that's the kind of information I'm looking for.
I guess I'll try to bring down the idle by swapping to SE 204 cams, which would make me a lot happier already.
In fact, the high idle is the only thing that bothers me on the TC96 and that's why I had the thought about the EVO, but the idea is written off by now.
Can't you bring down the Idle by resetting your PCIII? I think you can lower it by programing,but I saw on another post that you must not go to far as it can affect oil flow?
Old Apr 30, 2009 | 03:57 PM
  #33
Called2Duty's Avatar
Called2Duty
Have you thought of changing cams? maybe to SE 204's. I heard a TC96 the other day with SE 204's and it had a very low idle due to the lope and it sounded like an old shovel head. It definitely had that infamous potato,potato,potato sound to it.
iv got se 204s in mine and love the sound of the lope plus iv got almost 95 ilbs of torque
Old Apr 30, 2009 | 05:06 PM
  #34
CamFX's Avatar
CamFX
Whether you "new bike" people want to admit or not, the Evo is a much better engine for reliability and longevity. As to answer the original question, No it cant be done with out some serious frame reworking.
Old May 1, 2009 | 11:45 AM
  #35
Archer1968's Avatar
Archer1968
Hey called2duty is it possible to post a sound clip of your scoot?
Old May 1, 2009 | 11:29 PM
  #36
stratplexi's Avatar
stratplexi
First of all, lowering the idle down on a carb bike is not healthly for oil pressure. It is also not what makes the bike have a potato-potato sound. The potato sound has to do with the single pin crank and the way the bike fires, in terms of timing.
If you want to change the idle for a lopy, almost ready to die sound, simply buy a Screamin Eagle Race Tuner and adjust the idle table as low as you want. Just remember you are dropping the oil pressure down too.
If you want to make the engine sound 'meaner' and more like a hot rod, change the compression and cam. Bump the compression to 10.5:1 and add a longer duration cam like the 211 or 257 along with some ported heads and Bassani Pro Streets and the bike will sound better than any Harley EVO you have heard.
Old May 5, 2009 | 03:42 PM
  #37
howolf's Avatar
howolf
I just got off the phone with the Power Commander technical support dept.
and indeed, there's no map available for stage I plus the SE204 cams (or any other cams).
As some other people on this forum said already, the solution is to have it custom tuned (which is also depending on the kind of fuel you're usually running on) by a Dynojet Approved PC tuning center and that should be it.
Old May 5, 2009 | 10:27 PM
  #38
Archer1968's Avatar
Archer1968
Well, I better start getting the parts. I know there is a Dynojet facility here in vegas, but i think the dyno tunning will have to be done at the Speedway.
Old May 6, 2009 | 12:10 PM
  #39
howolf's Avatar
howolf
Looks like you will be faster to do the cam swap than i am... don't have the $$$ yet
Would you please keep us posted about this modification, Archer?
Hope you will be able to post a sound clip too.
By the way, I started another thread about lowering the idle by SE204 cams, here it is:
https://www.hdforums.com/forum/engin...ower-idle.html
Good luck,
and hopefully we'll be hearing more from you soon!
Old May 6, 2009 | 12:42 PM
  #40
Rail's Avatar
Rail
This is exactly right.. And adjusting the idle too low isn't a good idea on either a carb or inj bike.. 950 is the magic number when it comes to the twin cams with stock spring in the oil pump period... Baisley makes a stronger spring that's easy to install and will allow better oil pressure and a lower idle but again, not too low.. The 204's are a nice drop in cam and there are others from Andrews, HQ etc that might even be better drop in cams.. The 211 and 257 have a mean sounding idle but like posted above, you will need to have some headwork to get in the 10/10.5-1 compression range.. This can be done for as little as a few hundred bucks..
With an EFI bike you will need a tuner and the TTS is probably the best option for someone that doesn't have the means to spend a lot of time and money on a dyno as it has several maps that will be very close to your setup and you can fine tune the map with the v-tune program.. With the TTS it's also very easy to change the idle when you program the ECM.. Mine is set at 968 and with the 211's it sounds pretty wicked..
Good luck
