speedo/tach combo
Old Apr 28, 2009 | 01:18 AM
harleyheaven's Avatar
harleyheaven
I just installed a Dakota Digital combo unit and I love it. It's a plug and play unit with several programming options that are very simple. One option is a gear position indicator to tell you what gear you're in. You can send it to them and have your mileage set for $20. Check them out at www.dakotadigital.com/
Most places list them for around $500 but I got mine on eBay for $398 with free shipping. Cool looking speedo with some neat options!
Old Apr 28, 2009 | 01:50 AM
Archer1968's Avatar
Archer1968
I found this place, they have a good selection of aftermarket tach's
http://www.dumbassbiker.com/
Old Apr 28, 2009 | 07:35 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Where's the pics?
J/K, but if anyone else is interested in digital speedo's there are three out that I know of, there may be more, but I don't know of any others.
Does anyone know of any others?
The Dakota Digital is that blue/green color I'm not real fond of, but that's just my opinion. Other people seem to like it a lot.
For those of you who don't know about them, or have never seen one before, the Dakota Digital looks like this.
Then there is the Zippers that comes in a red/yellow color with a lot of the same functions for about $450.
I think it would look really nice on a red or black bike. It doesn't have a gear indicator, but does have a programmable shift light.
Then there is the Kuryakyn that's a little different, but it gives you the advantage of having a matching gas/battery and gas cap if you like.
The speedo lists for about $450 with another $125 for the matching gas gauge and fuel cap setup.
Unlike the Harley flush mount gas gauge, I don't remember hearing about anyone having trouble with the LED's in it.
If I was in the market for one of them, the Kuryakyn with its matching fuel/battery setup would be very appealing. The Gas cap also needs a 'key' of sorts to open it.
But leaves a ring around the hole when its open that should be nice for protecting the tank paint from the gas pump nozzle and spills.
And I like the way it changes color as you get up near the red line on the tach.
But the Zippers unit uses a line of LED's that run around the top 2/3rd's of the gage that should be fairly easy to read at a glance without really have to look at it and a programable
You just have to wonder how well any of them work under bright sunlight conditions.
PS. While the Kuryakyn and Dakota Digital have gear indicators in them.
There are no position sensors other than the sixth gear sensor in the tranny on newer (07 and up) bikes.
So they cheat and use the speedo's internal microcomputer to do a little math on the side.
When you program the unit it notes the ratio of speed vs. the engine rpm's in each gear.
Then it remembers those ratio numbers and uses them to do a little simple arithmetic to continuously calculate which gear your should be in.
JDJ
Jun 6, 2012 03:34 PM
mike79
Jul 18, 2011 05:21 PM
BlueBobber07
May 8, 2009 08:05 PM
D6CS
Jun 6, 2007 08:41 PM
Cessna172
Apr 22, 2006 01:11 PM
