Installing Bareback Saddlebag mounts
Old May 4, 2009 | 03:33 PM
Dustmaker's Avatar
Dustmaker
Default Installing Bareback Saddlebag mounts
OK, so what is the trick to get the bag on the strut hardware? It looks like it should slide right on???? Everything seems to be lined up, but I can not get either side to snap on.
Appreciate any help I can get from them in the know.
Old May 4, 2009 | 04:01 PM
StinkyPete's Avatar
StinkyPete
I have the same setup, make sure you are pulling the spring retainer thingys back. I still have to put the back on first and then rotate forward a bit to get the front on.
Old May 4, 2009 | 04:48 PM
schumacher's Avatar
schumacher
what kind of rims are those, Dust?
I like those
Old May 4, 2009 | 05:33 PM
Dustmaker's Avatar
Dustmaker
Seems like alot of work for as much as they cost....lol
I like those
They are DNA's...Thanks!
Old May 4, 2009 | 09:17 PM
tnharley7's Avatar
tnharley7
I just installed a set on my XBones last week. You must make sure that the slots are pointing down and not tilted to the sides any. Then slide back the spring loaded slide on the rear one and insert onto the bike. Then repeat for the front one. It is much easier to do the back first and just rotate the front in. It is almost impossible to put them both on at the same time. Also make sure that you don't have the washer on the bag side of the spring loaded slide...if so that might be interfering enough to keep it from sliding on. Jerry
Old May 4, 2009 | 10:15 PM
lionsqrne's Avatar
lionsqrne
Ditto.
Old Jul 10, 2020 | 07:26 PM
Hadye's Avatar
Hadye
and still, after 11 years, someone has the same problem
Sporty302
Jul 25, 2015 07:24 PM
bman7163
2014-2024 Touring Models
13
May 27, 2015 09:40 PM
mikeo33y
Apr 9, 2015 12:30 PM
Mathnerd
Aug 28, 2013 05:06 PM
sqrlnts
Apr 18, 2007 06:18 PM
