Hard starting problem
Old May 18, 2009 | 11:38 AM
Bogart99's Avatar
Bogart99
1st Gear
Default Hard starting problem
I have an '08 Fatboy (about 11k miles) with a Stage II kit and Vance & Hines exhaust. It has always seemed, to me, that it "turns over" slowly, and in the last few weeks, I've had some worries that it wouldn't start at all (like a weak/bad battery). At an independant shop the electrical system checks out OK. I ride fairly often, and keep it on a battery tender if I don't ride for more than 2-3 days.
Anybdy have a similar issue? Any ideas/fixes?
Bogart99
Old May 18, 2009 | 12:14 PM
79crash's Avatar
79crash
1st Gear
Isn't your bike still under warranty? I have an 08 rocker and it has sit for 3months without being turned over and started right up. U shouldn't have to keep it on the battery tender. Is it possible there is a problem with the battery tender?
Old May 18, 2009 | 01:10 PM
Bogart99's Avatar
Bogart99
1st Gear
Warrenty expired Feb '09. I have had it on and off of the battery tender for long periods of time - no difference.
Old May 18, 2009 | 01:58 PM
jblausey's Avatar
jblausey
I had the same issue with my Buell. Check and clean all ground points. I used dielectric grease after cleaning ground screws and grounding point. It fires right up with no hesitation at all now.
Old May 20, 2009 | 08:15 PM
jed1069's Avatar
jed1069
what fuel management are you using?
Old May 20, 2009 | 09:16 PM
RobbAR's Avatar
RobbAR
I had the same problem with an 08 Fatboy ...took it into the dealer to have it dynoed and the tech asked me if I had problems starting..he wound up replacing the starter as it wasnt strong enough to turn it over ...before changing the starter he changed the battery when he changed the starter it started just fine and havent had any problem since..
Mac10
Nov 17, 2013 03:28 PM
jerboys
May 7, 2012 01:23 PM
kipd
Aug 23, 2009 10:22 AM
tfuller
Apr 15, 2009 11:46 AM
cholmes
Jul 26, 2008 06:53 PM
