No Crank Issue
Old May 18, 2009 | 02:09 PM
petri48's Avatar
petri48
5th Gear
Default No Crank Issue
I just had to replace the battery on my '07 Night Train from sitting too long while I was out of state and now it won't crank(with brand new HD battery). I hear the starter solenoid push out but the starter doesn't turn. I checked all the fuses and relays, they were good. Am I missing something small or do I need a starter?
Old May 18, 2009 | 02:59 PM
chester1957's Avatar
chester1957
Make sure the battery is fully charged and cables are tight. If that doesn't help have an auto parts store load test the battery. A starter going bad just sitting there would be strange.
Old May 18, 2009 | 05:17 PM
petri48's Avatar
petri48
5th Gear
The battery is fully charged and I put a load test on it and it passed, everything is nice and tight. It started about a month ago but the battery was low so it took a lil to start up.
Old May 18, 2009 | 05:26 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Have you tried bump starting it? This would help you determine as to what possible issues might be.
Old May 18, 2009 | 09:56 PM
petri48's Avatar
petri48
5th Gear
I tried to bump start it and had no luck all I got was it barely turned once other than that it just locked up the rear tire. So where do I go from here?
Old May 18, 2009 | 10:06 PM
kfish1200's Avatar
kfish1200
1st Gear
Have ya checked your factory alarm? I have been told when changin the battery you have to reset alarm,Not sure how true that is just a thought!
Old May 18, 2009 | 10:15 PM
crazybastid83's Avatar
crazybastid83
Crank position sensor (located near your oil filter)
Old May 18, 2009 | 10:51 PM
oct1949's Avatar
oct1949
keep us posted as to what the problem is.
Old May 19, 2009 | 06:59 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Just for grin's try bump starting it in like 3rd or 4th gear instead of first.
Trying to turn the engine over at low speed in 1st is very hard because of the tranny, final drive ratio's. Doing it in the higher grears puts a lot less strain on the belt drive and can actually get the engine to turn over a bit faster.
If I have to guess it sounds a little like the Bendix drive on the starter may be stuck or broken. If its stuck bump starting it should free it, if its actually broken. Well you can guess the rest.
PS The "Security Sysstem II" isn't your problem. If its enabled (the fob isn't around) it will disable the starter, ignition, and fuel pump circuits. So turning the bike on and hitting the starter button will get you nowhere. It won't even try to turn over, or even make a noise like its tryin to. All that will happen is the all the turn signals will start blinking, and keep blinking for a couple of minutes, or untill the fob gets close enough to disable it..
Old May 19, 2009 | 08:25 AM
Mordrapheus's Avatar
Mordrapheus
damn I must be slow today...+1 on what citoriplus said about which gear to bump start it in.
