Led Lights fix????
Old May 19, 2009 | 09:12 AM
hogwildsr1's Avatar
hogwildsr1
Stage IV
Default Led Lights fix????
i have a 08 FLSTC and did some mods, cut the rear fender and insatlled leds, they work great with the stock front signals. i went and changed the front to lower profile but still conventional bulbs and now the flasher blinks correctly for about 3 sweeps then go faster making the security light come on. i do not have a security system so ?????? if i reinstall the original turn signals it work ok. i rang out the syatem and the original have less resistance ; any ideas???????????
Old May 19, 2009 | 11:59 AM
saintslax11's Avatar
saintslax11
you might need a load equalizer
Old May 19, 2009 | 12:26 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Load equalizer for sure as standard bulbs and leds draw different amount of power.
Old May 20, 2009 | 07:29 AM
hogwildsr1's Avatar
hogwildsr1
Stage IV
where and how do i find and know what kind of equlizer i need
Old May 20, 2009 | 07:40 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
The lower resistance of a LED makes them look like a short circuit to the flasher. So they blink a lot faster.
Unlike cars the TSM or TSSM (Turn Signal, Turn Signal/Security Module) in our bikes also has tilt and security circuits built into it. So you can't replace it with an electronic version and have to use a load resistor.
Check with any of the major lighting accessory makers Kuryakyn, Badlands, Biketronics, etc.
All of them have equilizer resistor setups, some are even fitted with the correct plugs so its a simple matter of plugging them into the existing circuit.
HyperM3
Apr 27, 2019 06:14 PM
Atlantaclassic
Electrical/Lighting/Alarm
Dec 12, 2017 08:58 AM
bikernutgoofy
14
Apr 9, 2015 09:05 AM
bigjosh42
May 13, 2014 07:28 AM
bosshog919
Nov 23, 2012 08:59 AM
