Swing arm bag
Old May 21, 2009 | 06:25 PM
redmustang1990's Avatar
redmustang1990
Default Swing arm bag
Does anyone use a swing arm bag and still have a side mount license plate? Is that even possible? I have a 2006 Nightrain and I want to have some type of smaller bag without going to saddle bags. If you have a suggestion I would like to hear it.
Old May 21, 2009 | 07:33 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Get the kury side mount plate that mounts on the swingarm and put it on the other side.
Old May 21, 2009 | 07:35 PM
Reino_79's Avatar
Reino_79
As long as you plan on leaving the swingarm bag on and its wide enough, why not just mount the plate on the backside of the bag, sideways of course. That would look sweet I think.
Old May 21, 2009 | 08:03 PM
Reino_79's Avatar
Reino_79
I just measured the plate and back of my swingarm bag from HOG Deluxe. The plate is 4" x 7" and the bag is exactly 4" wide. If you attach the plate so the top is right where the flap starts the bottom of the plate would be about 3/4" below the bottom of the flat back of the bag, where it begins to curve to the bottom. You might even be able to bend the bottom portion of the plate so it follows the bottom curve of the bag.
If I havent confused you yet Id be suprised, cause after reading this Im confused and I did all the measuring and explaining.
Last edited by Reino_79; May 21, 2009 at 08:05 PM. Reason: To try and make it easier to understand.
Old May 22, 2009 | 02:02 AM
travis dasher's Avatar
travis dasher
Yes a swing arm license plate mount frame will fit with a swing arm bag. You will have to move the bag forward an inch or so but it will fit and still leave enough room for the passenger to put their feet on the pegs. check my pics
Old May 22, 2009 | 05:36 AM
ptw***'s Avatar
ptw***
I have the Leatherworks 312X & the license plate bracket mounted on rear axle. No problem.
Old May 22, 2009 | 06:10 AM
DragonSlayer08's Avatar
DragonSlayer08
It works with an axle mount side plate also.
Old May 22, 2009 | 08:48 AM
phantom rider's Avatar
phantom rider
It ended up working on mine... Here is the pic...
Old May 22, 2009 | 02:05 PM
Dennis@TopDownProducts's Avatar
Former Sponsor
Top Down Products has the answer...
...a license plate mount that fits directly off the rear axle and will rotate between horizontal and vertical without needing any tools.
I'm from Top Down Products and we have a truly unique and versatile product. Our mount is available in Chrome, Gloss or Flat Black Powder Coat. It fits virtually every make and model Harley and some non-HD's as well. Here are some pics of the product. Check out our website www.topdownpro.com for more details on the product and mounting options. For the Rocker, I recommend the Axle Mounting.
Dennis
Attached Thumbnails Swing arm bag-dscn3145.jpg   Swing arm bag-dscn3146.jpg   Swing arm bag-roto-plate-press-release.jpg
Old May 23, 2009 | 09:51 PM
Diskon1's Avatar
Diskon1
Any axle mount plate mount should work. Mine does.
saltlick
Mar 22, 2017 11:57 PM
nighttraindreamin
Nov 14, 2013 03:03 AM
Six16
Sep 12, 2013 05:40 PM
bobbsterkid7
Jul 25, 2007 10:26 PM
mikec
Sep 23, 2006 11:44 PM
