Break Heat/ Rub
Old Jun 1, 2009 | 08:51 PM
tripwire759's Avatar
tripwire759
Default Break Heat/ Rub
After getting a rear flat today I had my bike towed into the local dealer. I waited 4 hours I had a brand new tire put on. On the way home I noticed a funny smell and heard a light squeek. When I pulled up to a light my rear break started to squeel. As I looked at it, it appeared to be discolored as a piece of metal looks after it has been heated up (brownish).
My questions to you guys are;
1. Do you have to remove the disc off the rim to put on new rubber?
2. Did the guy doing it tighten the breaks up so now they are rubbing?
3. How warm are the disc going to get coming from a 45 MPH stop and should my glove start to smoke when I touch it real quick?
BTW if you have the wheel and tire coverage it works like a champ! $110 tow, $189.00 tire, and $65 (I think) labor charge...FREE!
Old Jun 1, 2009 | 09:04 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Tom here.
No
I don't know
No
When the rear wheel is removed to change a tire sometimes the brake pads and pistons in the caliper need to be pushed back slightly to get the wheel back over the disc. If it were me, I'd take it back to the same guy and show him what happened. You could pull the wheel, remove the pads, clean the pistons, put it all back together and see if that makes a difference.
Regards,
Tom
Harley Goodies
Old Jun 1, 2009 | 09:21 PM
DyNaBoB's Avatar
DyNaBoB
sounds like a 18 year old changed your tire and put the wheel back on off center so by the sounds of it you now need a new rotor (warped from the heat)and brake pads.....oh and check your belt too that might have rubbed on the pulley too
Old Jun 1, 2009 | 10:14 PM
crazybastid83's Avatar
crazybastid83
Wow!!!!!!! You are amazing! You can diagnose all that over the internet? First of all, on a tire change, the caliper pistons are pushed back into the bore in order to remove the caliper from the rotor and to make it easy to slide it back on. Secondly, I doubt if the tech even touched the adjusters, he loosened up the axle, popped it out, remove the wheel, then replaced the wheel after the tire change.
There is no adjustment to the brake pads, you seat bolts and torque them, if you even do that in this case, which you don't.
Old Jun 1, 2009 | 10:45 PM
DyNaBoB's Avatar
DyNaBoB
lol didnt know i diagnosed it, i said SOUNDS like and he will proly have to replace the rotor cuz it got so hot.........and any tech that takes a wheel off should lossen the adjusters and adjust belt tension when the wheel is put back on.........and to check his belt to see if that rubbed............did they teach you to read in NJ
Old Jun 1, 2009 | 10:50 PM
crazybastid83
Did they teach you to read in NJ?
I learned to read in NYC. I guess you were never taught how to work on a bike where ever you are?
Obviously there is a problem. Let him take it in to check it out. Some things can not be diagnosed over the internet, tough guy! You sir are a douche!
Old Jun 1, 2009 | 11:00 PM
DyNaBoB's Avatar
DyNaBoB
lol........again if you READ his post ,it was fine,, he got a flat, they fixed it ,and he left and all this happened im am telling him he needs a rotor from all the heat (his glove smoked when he touched it) its gotta be warped, and to check his belt too so if its effed up they can replace all this cuz they did it..........and yea im tough.......well tougher than you anywho
Old Jun 1, 2009 | 11:07 PM
LH's Avatar
LH
Well, most of us know that Crazy is a certified HD mechanic and works for a dealership. He has gone out of his way to help out a lot of folks on this site with his knowledge.....
So Mr.Dayna what do you do for a living ??????
Old Jun 1, 2009 | 11:16 PM
DyNaBoB's Avatar
DyNaBoB
lol another one that cant read................dont remember READING this thread being about wut i do for a living..................just cuz hes certified dont mean nothing when he didnt even read he just shot off cuz i said the tech was an 18 year old now there is 2 of ya acting like 18 year olds..............quit ****ing up this guys thread
Old Jun 2, 2009 | 12:20 AM
VTwin-Goodies
Former Sponsor
Tom here again. I don't know about you, but I don't push the pistons back into the caliper until the caliper is off the bike. The resr of you guys need to lighten up a bit.
Regards,
Tom
Harley Goodies.
