I need some help
Old Jun 4, 2009 | 12:41 PM
PTAG's Avatar
PTAG
Default I need some help
I recently bought a used 2009 Heritage Softail Classic. When I got it it had Rush slipons but no stage one. I bought the screaning eagle air fliter and a power commander V.
When I start the bike cold it the engine cranks a few seconds and starts. If I punp the throttle a couple of times when cold it starts right up like my Ultra Classic. Both are fuel injected.
Last night I removed the Power commander to see if it had interferred with anything and it did not help. Tonight I am going to check the rubber hoses that came with the air filter kit and make sure they are not stopped up.
When I turn it on I hear the fuel pump running up as normal.
I don't remember it acting like this before I changed the air filter but I could be wrong.
It there anything else I can check myself. Is there a ckoke flap on FI models? Maybe the flap, if there is on, is stuck and comes loose when I work the throttle.
Let me know if you have any ideas.
Thanks,
Hal
Old Jun 4, 2009 | 04:29 PM
Cheesecake's Avatar
Cheesecake
you turn the bike on...
the fuel pump starts to pressurize the system...
do you wait for the check engine light to turn off before you hit the button?
Old Jun 4, 2009 | 04:43 PM
PTAG's Avatar
PTAG
Yes, I wait for it and the alarn key light to go off.
Old Jun 4, 2009 | 04:50 PM
Xuallus's Avatar
Xuallus
there is no choke on EFI models, the air/fuel ratios are all controlled by the computer.
I'd try starting it with the AC off. If that helps, then you know you have a problem with that install.
Old Jun 4, 2009 | 08:20 PM
crazybastid83's Avatar
crazybastid83
I believe with the power commander, you can add more fuel for start up. Send them an email. You don't have to wait when starting a fuel injected bike. It was HD's original instructions, but they have found it is no longer necessary. Some people at dealerships still instruct new owners to wait for the fuel pump to pressurize the system.
Old Jun 4, 2009 | 08:21 PM
zoomie67's Avatar
zoomie67
Did you by chance upload the proper map th the Power Commander?
Old Jun 4, 2009 | 09:20 PM
Cheesecake's Avatar
Cheesecake
I have heard that.... mine starts "quicker" if I wait until the check engine light turns off.... If I turn it on and instantly hit the starter button it turns over a few times before she fires up....
CC
Old Jun 4, 2009 | 09:25 PM
anubisss's Avatar
anubisss
Set the throttle position on the PC too. I don't anything about the 5, but on the pcIII I had to set the throttle position.
Old Jun 4, 2009 | 09:29 PM
harley albert's Avatar
harley albert
Default I second the upload on the power commander
I have an 05 fatboy with rush slip ons, performance filter and power commander. There is a specific map for this combination. Granted you have the 96 ci but they have the map.
Maybe your download of the map was not successful. Contact Rush and they will help you. Great pipes and a great price! Better than Scraming Eagle pipes.
Old Jun 5, 2009 | 07:14 AM
tk353's Avatar
tk353
he said he removed the power commander so it is not the cause, so all the answers about the PC would not help except the one about the additional fuel. to me it sounds like a vacuum leak
