Is this normal?
Old May 15, 2006 | 11:07 PM
Crazy Canuck's Avatar
Crazy Canuck
Default Is this normal?
I just received my bike from the shop. I installed new
front and rear wheels along with a new pulley and two
rotors. The belt makes no noice when I'm rolling forward
but makes noise when I roll it backwards. Like I hear each
tooth of the belt when it enters the pulley. This however was
not the case when the bike was off the ground. It only does
it when it's on the ground. Should I be concerned?
Crazy Canuck[sm=smokin.gif]
Old May 15, 2006 | 11:26 PM
Maddogs700srx's Avatar
Maddogs700srx
Default RE: Is this normal?
My 98 FB has the same noises. No problems so far.
Old May 15, 2006 | 11:32 PM
JB's Avatar
JB
Sounds like the belt is to tight
Old May 17, 2006 | 12:08 AM
daboys53119's Avatar
daboys53119
My fatboy doesn't do it but my Father's Roadking does. I have heard of this before but not sure if anything is wrong. Have you changed your tire size? I may be wrong but maybe if you change your rear tire size I think the belt rubs but only when backing. Just my 2 cents.
Old May 17, 2006 | 12:47 AM
Crazy Canuck
Hey Ted
Actually I changed from the stock 17" to an 18".
Old May 17, 2006 | 01:31 AM
pro1955's Avatar
pro1955
My bike did the same thing when I changed wheels, I loosened up the belt alittle bit made it better.
quackattack
EVO
15
Mar 26, 2018 04:44 PM
98hotrodfatboy
19
Feb 26, 2018 05:51 AM
magnashopper
May 24, 2015 11:20 PM
ronjon8505
Jul 19, 2013 07:24 AM
jokenroll
EVO
Nov 3, 2012 12:50 AM
