05 Springer Classic slipping in corners
Old Jun 12, 2009 | 05:20 AM
OLE1's Avatar
OLE1
Stage II
Default 05 Springer Classic slipping in corners
Hey there Springer owners, has anyone experienced there rear tire slip when taking a corner? Checked the tire pressure and it was right on. It had rained earlier in the day but road seened dry. It happened twice today, once on the way home for lunch and once on the way back. Any help would be greatly appreciated.
Cheers Ole....
Old Jun 12, 2009 | 06:52 AM
DaddyKnuck's Avatar
DaddyKnuck
Oil? Debris?
A few years back I crashed on a mountain road at night. Even on the ground I couldn't see anything to make me lose traction. The next day I was able to see some fine black sand that breaks off from the cold pack they use to repair the roads.
Old Jun 12, 2009 | 07:27 AM
Zacharia_11's Avatar
Zacharia_11
Grated Road, painted line? I have not slipped on anything that I shouldn't slip on, like gravel, sand, painted lines and I seem to wander but not slip on grated roads.
Old Jun 12, 2009 | 07:47 AM
GymRat523's Avatar
GymRat523
Not yet on my Bones but we have one corner on an exit ramp when I go home that is always slippery, even dry. My Sporty has lost traction a couple of times. Could it be a high traffic area with a stop? They tend to build up some road grime.
Old Jun 12, 2009 | 09:22 AM
Dlish's Avatar
Dlish
rain always brings any oil and grime that is in the grooves of a road back up to the top. never had any problems with my fxsts
Old Jun 12, 2009 | 11:16 AM
bensonjv's Avatar
bensonjv
Debris, oil or other liquid, road lines, and rain are the likely candidates. Also consider tire temp. Cooler tires are more slippery and can give out if you push them too far too fast. Give them a few miles to heat up.
Old Jun 12, 2009 | 12:27 PM
softail04's Avatar
softail04
only had that happen once and not on my harley, was comming to a stop sigh after about 40 miles of freeway on the offramp the rear tire just stepped out had both front and rear brake applied slightley so let off to try and straighten it up was almost stopped befor it finally laid down , went back and looked for the reason nothing to be seen except fresh paint on a turn arrow, maybe ?????
Old Jun 12, 2009 | 01:09 PM
gaffster01's Avatar
gaffster01
Paint lines, tar lines, and sand/gravel only thing I have ever slipped on.
Old Jun 12, 2009 | 04:25 PM
Slowpoke84's Avatar
Slowpoke84
When my last rear tire started to wear, it felt like my rear end was sliding around corners. It got really squirrelly. I looked at the tread and the wear was uneven and the tire was cupping a little. Maybe it's time for a new tire?
Old Jun 14, 2009 | 08:39 AM
OLE1's Avatar
OLE1
Stage II
Thanks for all the replies, I think the oil other contaminates were surfacing after the rain. Has not done it since that day.....
Cheers Ole....
