Danny Gray = poor quality control
Old Jun 15, 2009 | 07:20 AM
kanunski's Avatar
kanunski
well i'm hoping for better things, mine is in the final stages of being made, have read nothing but good things about them on other posts, will let you know how it is when i get it.
Old Jun 15, 2009 | 10:02 AM
97FXSTSB's Avatar
97FXSTSB
I'm seeing more and more bad press on Danny Gray seats. I thought he was supposed to be the best? Oh well...
Old Jun 15, 2009 | 11:10 AM
yep's Avatar
yep
Account Suspended
I dont want to start anything here but did you give them a chance to fix the problem . and just for future referance I make sure all my bolts are free of bures and go in easy before I start installing things ... have you thought about having a welding shop drill and tig a threaded tube into the hole ... must be tigged so that its clean and wont get splatter on everything but it could work
Old Jun 15, 2009 | 11:37 AM
Havanacigar's Avatar
Havanacigar
Well that sucs...I was just about to re-order a buttcrack solo...Just curious, was the seat comfortable?
Old Jun 15, 2009 | 11:40 AM
BigSeaDaddy's Avatar
BigSeaDaddy
Originally Posted by speedsnice
It has gotten to the point that I dont want my Rocker anymore.
Dude, making it your own is part of the fun even when things do not go right. I know your not serious about giving up you rocker just cuz a bolt pissed you off. Sorry about all your frustration.
Old Jun 15, 2009 | 12:42 PM
bensonjv's Avatar
bensonjv
Sounds like a very expensive lesson. I completely understand your frustration and I wish things had gone better for you. But from your description of the sequence of events it seems you had several opportunities to stop. The gremlins were yelling at you and you weren't listening.
You said you immediately realized the seat brackets weren't lining up. Then you took it upon yourself to try to "fix" the brackets so they would fit. Didn't work. Despite the brackets being off you still chose to try to install the seat.
Upon forcing the installation you cross threaded a bolt. Trying to get it out or in you stripped the bolt head. Then you grabbed vice grips; the use of which caused you to break off the cross threaded bolt in the frame. Your subsequent efforts to successfully extract the cross threaded bolt half resulted in destroying the bolt hole.
Monday morning quarterbacking, I think I would have stopped as soon as I realized the brackets were off. Verification via instructions, web, phone contact to DG directly, or a trip to my local indy wrench for a second opinion would have been in order. Its possible you were sent the wrong seat, their template is off, or something else out of your control. For the amount of love, time, and money we pour into our motorcycles, there is no place for "blankity-blank" engineering efforts.
My last thought: Vice grips on my Schwinn banana bike - ok. Vice grips on my Harley - not ok. Only the right tool for the job on something as important and expensive as my motorcycle.
Again, wish things had gone better for you.
Old Jun 15, 2009 | 12:58 PM
DragonSlayer08's Avatar
DragonSlayer08
I believe you need to make a clear distinction between the Danny Gray production seats and the Danny Gray custom seats. Sorry to hear about your problems and the frustration it has caused you.
Old Jun 15, 2009 | 01:07 PM
LEGENDCHROME's Avatar
LEGENDCHROME
That sucks about the seat and the bolt hole, I have run 3 DG seats and have nothing but good experience's with them. I have run the Butt Crack, Big Seat and the Everyday solo. The Big Seat being the current one on my bagger, I love it.
Old Jun 15, 2009 | 01:18 PM
speedsnice's Avatar
speedsnice
I am going to use JB Weld to fill in the hole then I will redrill and tap it, hopefully that will work.
Old Jun 15, 2009 | 01:28 PM
DragonSlayer08
I hope it works for you, you certainly have a beautiful bike!
