Brake Pads
Old Jun 15, 2009 | 08:50 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
First good advice here is lyndall's. It does sound very soon. Learn to use the front brake as well. The front brake provides most of your stopping power. I use the z plus pads and they last a long time.
Old Jun 15, 2009 | 12:49 PM
flst06's Avatar
flst06
My rear pads were completely shot at 10K - super easy DIY replacement.
Rear tire going strong at 14K; hopful I can make it thru the summer.
Don
Old Jun 15, 2009 | 01:34 PM
PirateRider's Avatar
PirateRider
Thanks for the advice guys. I actually do use the front brake primarily (more pressure)but use them both in almost every stop. It seems that only the outside rear pad is overly worn-after looking at it better. The inside is still in good shape. I will take it in this week to get an understanding of the uneven wear and questionable performance.
If they replace under warrenty then HD brakes - if not i will go lyndall.
Old Jun 15, 2009 | 05:20 PM
tk353's Avatar
tk353
i had the uneven wear also on the stock pad. just be sure to clean the pistons when you replace the pads and i also too the time to replace the fluid. http://www.lyndallracingbrakes.com/service_tech.htm
Old Jun 15, 2009 | 08:25 PM
luc.who's Avatar
luc.who
I replaced my stock pads at 8500 miles to get rid of the brake squeal. I used the lyndal gold pads and was pretty happy until this weekend. The gold pads are now squealing. If you are going to lyndal pads, use the Z+ pads. I missed the post that these are the ones that don't squeal.
Old Jun 15, 2009 | 09:44 PM
tk353's Avatar
tk353
i have the Z+ and they squeal. I think they just need washed
Old Jun 18, 2009 | 05:47 PM
mrworld's Avatar
mrworld
Stage IV
My rear pads are down, and have grooved the disc....5100 miles 2008 softail
That doesn't sound normal...although I may be over using the rear brake ....surely not that much.
I pretty much use the front/back simultaneously. I will start to rely more on the front.
Back to the dealer this week...better be under warranty...ya think?
Thanks all
Old Jun 18, 2009 | 05:50 PM
tk353's Avatar
tk353
they wont warranty unless there is a defect in the part and most will tell you no but if the dealer cares they should reach agreement with you even if free labor only
Old Jun 18, 2009 | 06:01 PM
mrworld's Avatar
mrworld
Stage IV
Thanks tk353
So, are the Lyndal Z+ pads are the best I can get?
Any suggestions on replacing the disc?, or no need?
Old Jun 18, 2009 | 06:44 PM
'05Train's Avatar
'05Train
If you've got a groove in your rotor, it needs to be replaced.
