thundermax autotune does not see either 02 sensor
Old Jun 20, 2009 | 07:26 PM
tk353's Avatar
tk353
Default thundermax autotune does not see either 02 sensor
went to the last map it made and still runs but cant take off fast. i got home and connected to the computer and it does not read either 02 sensor, has anyone seen this issue and know of a fix? i have not reinitialize it yet
Old Jun 21, 2009 | 03:25 PM
tk353's Avatar
tk353
the data port wires got cut from the bottom out i did today. i think the passenger but i wont tell her that. solder the wires and all is fine.
Old Jun 21, 2009 | 03:48 PM
hdokie's Avatar
hdokie
so just how do you gain with one of these tuners?
Old Jun 21, 2009 | 03:49 PM
tk353's Avatar
tk353
gain what?
Old Jun 21, 2009 | 03:52 PM
hdokie's Avatar
hdokie
power/performance, is it worth the money?
Old Jun 21, 2009 | 03:57 PM
tk353's Avatar
tk353
performance is great compared to stock, i dont know what gain i get but it would be from the pipes and breather and not the fuel management. that is for the right air fuel racio and the auto tune keeps it adjusted correctly for all condition i ride in. i can change pipes and dont have to pay someone to retune
Old Jun 21, 2009 | 04:14 PM
chunks's Avatar
chunks
Sounds like you need to adjust your shock pre-load if you are bottoming out
Old Jun 21, 2009 | 04:18 PM
chunks's Avatar
chunks
Absolutely. Biggest return if you have upgraded your intake and exhaust, etc
, not so much if you are leaving the bike totally stock.
Might run a bit cooler and smoother and be a touch more responsive even
if you are dead stock.
They tune them to run extremely lean from the factory to meet emission requirements.
Old Jun 21, 2009 | 04:21 PM
tk353's Avatar
tk353
i need a lighter passenger.
Old Jun 21, 2009 | 05:21 PM
rbabos's Avatar
rbabos
For what it's worth I never ran my wires for the O2s according to instructions. (softail) Behind the battery and down is where I routed it. Looked at removing the plate behind the fuse box but decided that blows. Had more room between the battery and oil tank, plus gained some length in the O2 wires to the front sensor. Second thing was splice more wire into the data port section to allow the plug to fit more in the middle of the seat. It was always getting mashed from the stock position from the factory. Don't be afraid to do some custom wiring in there to make it right if needed. Viewing the underside of the seat will show any major contact areas, or use a grease pencil on parts to see where it transfers to the seat.
Ron
