Brake question
Old May 21, 2006 | 10:45 AM
smithk's Avatar
smithk
Default Brake question
Noticed that I get a little squeak in the rear brake once in a while. Yesterday when I got home I checked the front brake disc and it was warm to the touch. The rear disc was HOT. Is this normal? Thanks for the info.
Old May 22, 2006 | 01:16 AM
tripl8's Avatar
tripl8
Default RE: Brake question
yes............................................... ...............
Old May 22, 2006 | 01:27 AM
Alien Spyder's Avatar
Alien Spyder
Funny you mention it, I just started getting a little squeek out of the rear break. Never had it before. I'm just approaching 8900 miles. How long do pads usually last??
Old May 22, 2006 | 07:03 AM
Nasty350LT1's Avatar
Nasty350LT1
It all depends on how you ride. I have over 22,000 on my original pads.
Never had a problemyet, with squealing or squeaking in the least.
Old May 22, 2006 | 11:30 AM
smithk's Avatar
smithk
Rode the bike to work this AM and checked the disc and it was just warm to the touch. When I checked it Sat., I had just got done riding 85 miles. I am probably guilty of not using the front brake enough. Am going to try and change my braking which should help a little. My bike was new last year and only has 4600 miles on it.
Old May 22, 2006 | 02:40 PM
pro1955's Avatar
pro1955
My brake pads only last about 10k, the rear does squeek, not sure how to stop it I tried the stuff that you paint on the backside of the pad, it only works a couple thousand miles. I think the temp issue is normal, I hate to think the squeek is normal, I have noticed the hotter it is outside the worse it is.
Old May 22, 2006 | 06:26 PM
GADave's Avatar
GADave
ORIGINAL: smithk
As another guy said "yes" this is normal. Also, I'd recommend against touching the disks after you're done riding, hot doesn't begin to describe what they can be. Ever watch a NASCAR cup race at Martinsville? Disk rotors glow bright orange-red. Accidently touched a disk on my truck once and burnt the skin off my finger - hurt like a goner clamp. A little squeaking isn't unusual either and certainly doesn't mean your pads are worn or wearing out prematurely.
Dave from Georgia
2004 FLSTCI
Old May 23, 2006 | 08:28 PM
Mike05's Avatar
Mike05
squeak=bothersome
grinding=$$$$$$$$$$$$$
Old Jul 2, 2007 | 09:37 AM
Road_Clam's Avatar
Road_Clam
I tried coating the back of the pads with anti-seeze, and it made the squeeling less, but not for long. Now 2 weeks later I have normal squeeling again. Luckily I only use my rear brakes minimally.
Old Jul 2, 2007 | 09:42 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Check out these guys, everyone who's tried them think the factory did us a diservice not putting these on the bikes going out the door. Sone as I can get some extra money together I'm getting their pads and two piece stainless steel rotors.
http://www.lyndallracingbrakes.com/products.htm
But if your just looking to get rid of the noise and 'GD' dust, check them out.
Damn, I gotta learn how totype better. Alweays having to fix my screwups.
