'09 Crossbones tools
Old Jul 5, 2009 | 01:37 PM
Pussboy's Avatar
Pussboy
Default '09 Crossbones tools
I would like to put together a toolkit to cover all maintenance and repair needs at home. Can you give me a list of what I need? Thanks!
Old Jul 5, 2009 | 04:37 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Start with a Service manual for your bike and a good floor jack with at least a 1000 minimum weight rating.
Essentially all the Torx including the 5 big ones that go on a ratchet. So the small ones that come on a multi piece key and the big ones that are ratchet driven
Full spectrum of allen wrenches. Same as above. Small ones on a key and the larger sizes that are ratchet driven.
Big cresent wrench and a small one.
Full set of SAE open ended wrenches.
Full set of SAE sockets and various lenghts extensions.
A high quality Torque wrench.
Rubber mallet.
Soldering iron just in case.
Few flat tip screwdrivers and a couple phillips.
Then make sure you have the typical assortment of needle nose pliers, vise grips, and wire cutters.
I know I'm forgetting something but those are the ones you will use most often.
Old Jul 5, 2009 | 08:00 PM
Zacharia_11's Avatar
Zacharia_11
For your bones you'll want.
Motorcycle Jack - I just ordered a J&S Jack, it'll be here tomorrow!
Neck Bearing Adjustment Tool for SpringerŽ Forks
Rocker Arm Adjustment Tool for Harley-DavidsonŽ SpringerŽ Motorcycles
Last two items I picked up from A & E Hand Tools.
Old Jul 5, 2009 | 08:02 PM
Zacharia_11
Also grab a parts book. Great for replacments & the exploded views have been very helpful in my projects!
Old Jul 5, 2009 | 08:20 PM
Pussboy's Avatar
Pussboy
Thats exactly what I was looking for! Thanks!
Old Jul 5, 2009 | 08:23 PM
Pussboy's Avatar
Pussboy
Anybody have the part # for the service manual?
Old Jul 5, 2009 | 08:30 PM
Rakthi's Avatar
Rakthi
2009 Softail Models Service Manual: 99482-09
2009 Softail Models Parts Catalog: 99455-09
Old Jul 5, 2009 | 08:32 PM
Pussboy's Avatar
Pussboy
Thanks dude! That was fast!
Old Jul 5, 2009 | 08:46 PM
wildman67's Avatar
wildman67
Also make sure you get a T-27 torx bit. its used alot on softails and isn"t included in alot of torx bit sets.
Old Jul 5, 2009 | 10:07 PM
xraybox's Avatar
xraybox
as for manuals, you might want to add :
Electrical Diagnostic Manual 99498-09
the service manual periodically refers to it.
Zacharia's tool suggestions are what I'll be getting (other than jack, have crapsman jack).
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
