Adjusting shocks
Old Jul 14, 2009 | 07:17 PM
Jim Kraft's Avatar
Jim Kraft
Default Adjusting shocks
I tried to adjust the shocks on my 99 Softail Custom, and the nuts were very tight, but I got them loose OK. My problem is the left shock turned OK with the spanner, but the right one won't budge. Any body else have this problem? Kind of hate to resort to heat, but might try a heat gun on it. Maybe some WD-40 would loosen it up. Got suggestions? Thanks; Jim
Old Jul 14, 2009 | 07:42 PM
CANTDR55's Avatar
CANTDR55
Spray the hell out of it with some kind of penetrating lube for frozen nuts etc, Liquid wrench is great, and let it sit over night. Has helped me out in the past with stubborn bolts etc.
Old Jul 14, 2009 | 08:14 PM
Blk and Chrome's Avatar
Blk and Chrome
+1 on that, try working it back and forth
Old Jul 14, 2009 | 09:03 PM
Jim Kraft's Avatar
Jim Kraft
Thanks guys; I will hit it with the penetrating lube and let it set. Then try working it back and forth. Or as an old mechanic in our town use to say; Don't force it- get a bigger hammer. LOL
Old Jul 16, 2009 | 12:22 PM
WFA's Avatar
WFA
Hey Jim...not sure what you can't turn but I assume the canister end plate/adjuster. Saturate the treads with "BLASTER PB". The best i have found for freeing frozen/rusted metal parts. Available at Advance Auto and Walmart too. Reasonable price. Beware of too much heat as the softail shocks have a "plastic" spacer on the inside of the plate you are trying to turn. Good luck !!
Old Jul 16, 2009 | 03:53 PM
Jim Kraft's Avatar
Jim Kraft
Thanks Woody; I will try the BLASTER PB. I shot it with WD 40 the other day, but still won't budge. Thanks for the tip about the plastic spacer. Yes, it is the end plate adjuster that seems to be stuck. Thanks again; Jim
Old Jul 16, 2009 | 05:49 PM
tmitchellof PG's Avatar
tmitchellof PG
When you get both shock bodies loose, turn them both one way or the other so you get an even starting point. When you adjust them, if you need to go completely one way or the other, when they stop turning, turn them back the other way just an 1/8 of a turn or so. Next time you adjust them they wont be stuck all the way open or closed.
Tom
Old Jul 17, 2009 | 08:55 PM
Jim Kraft's Avatar
Jim Kraft
Thanks for the tip Tom. I hit it with the Blaster PB tonight, and I will work with it tomorrow to see if I can pop it loose. Thanks again for all your help you guys. Jim
Old Jul 20, 2009 | 11:57 AM
Jim Kraft's Avatar
Jim Kraft
Thanks to all you guys I got my shock loose. I used the Blaster PB and made a special spanner that I could get a big wrench on and that did the trick. I think you were right Mitchell, as the one that was stuck was adjusted clear to the end. Mine also have the adjustable lowereing bolts in them, so was able to set those where I wanted as well. Thanks again; Jim
papo57
May 29, 2014 07:57 PM
MGN54
Jul 30, 2010 06:19 AM
jp1212pc
May 30, 2008 07:22 PM
DAVE12345
Jul 13, 2007 07:44 PM
medic434
Jul 12, 2007 03:34 PM
