DemonCycle Headlight Bulb Failure
Old Jul 16, 2009 | 01:11 PM
Ruralmed's Avatar
Ruralmed
Default DemonCycle Headlight Bulb Failure
I put the $89.00 cheapo bullet headlight on my FCWC, because it looks cool and not as pricey as the $600 headwind version. However, I power washed it after riding across the salty Nevada Dessert and the bulbed burned out the same day. Would moisture cause this? There is a small hole under the headlight for the wiring. First I lost the low beam (1030pm going over mountain pass), then the high beam the following day.
Old Jul 16, 2009 | 01:43 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
It may be just a coincidence. But that place has a bad reputaion around here for selling junk parts.
So my first instincts would bet to pull the light apart and check it out.
Make sure that the new bulb you put in has plenty of dielectric grease on both it and in the socket. That will waterproof the connections and hopefully prevent any water that does get in from getting to the connections and possibley shorting things out on you.
Also double check the assembly and sockets mountings. Most good headlights will have some kind of shock absorbent mounting for either the entire light assembly or the bulb socket inside. It may only be a rubber ring around the socket, but there should be something in there to absorb most of the really bad vibrations.
And last would be to look over the bulb (the old one) itself, even money says its a cheap Chinese POS that couldn't handle the water, the vibration or maybe even both.
Get a good brand name replacement bulb (like a Sylvania Silverstar or Ultra). They are designed from the get go to be heavier than normal in order to handle the vibrations. Put on plenty of dielecrtic grease and remember wear gloves or something to prevent your fingers from touching the glass.
I always wipe off any bulb I fool with with alcohol after its installed just to make sure that it's really clean.
Otherwise the bulb is likely to fail in a fairly short time frame becasue of what the acids on your finger tips will do to the glass once it starts heating up.
Old Jul 16, 2009 | 01:51 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Pressure washing is a no no in my opinion and I think that is the cause. If you use a regular hose without a nozzle it is unlikely this would happen, but then again it is from demons cycle. I'll spare you the rest of the lecture. But check the grease on your axles if you pressure wash regularly. There might not be any there.
Old Jul 16, 2009 | 02:11 PM
saintslax11's Avatar
saintslax11
Check the bulb and see if the reflector was rubbing on anything. I had one from Eastern Performance and the reflector rubbed it to the point of going out. I would say Vibration.
Old Jul 16, 2009 | 03:40 PM
jisham's Avatar
jisham
DemonCycles is the WORST online dealer I've ever dealt with.
Old Jul 16, 2009 | 04:20 PM
PureDeath's Avatar
PureDeath
As stated above..................Vibration will pull it to the test quickly!
As that ole saying goes..............ya get what ya paid for!
Old Jul 16, 2009 | 04:56 PM
saintslax11
+1..... could not agree more
Napalm Dog
Mar 12, 2014 05:57 PM
DPete
Aug 4, 2010 10:52 AM
Tuco069
Jul 26, 2009 06:03 PM
yoseppi
Apr 26, 2009 09:54 AM
JBA111
Aug 21, 2006 11:44 PM
