Thinking about fitting Beach Bars
Old Jul 27, 2009 | 02:37 AM
painey's Avatar
painey
Default Thinking about fitting Beach Bars
I keep thinking about fitting beach bars, I feel the drag bars look to narrow for the low wide stance my bike has got, also as the frame has been stretched it will help control the 'drop' when doing slow turns.....what do you think?
Old Jul 27, 2009 | 03:20 AM
Teamcat's Avatar
Teamcat
I think a set of apes would look Just as good or better
Cheers Cat!
Old Jul 27, 2009 | 06:09 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Beach it or Ape it...One or the other. Drag bars on a Fatty? No good IMO.
Old Jul 27, 2009 | 07:37 AM
painey's Avatar
painey
Just what I was thinking, prefer to go with beach bars.
Is it a tricky job and how long do these take to fit, I only get to ride my bike when I visit Florida (try and get over twice a year) and time is normally tight, I want to ride my bike not do changes.
Old Jul 27, 2009 | 09:41 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
If you wire the bars internally and you will most likely need to replace throttle, brake and clutch cables schedule yourself at least an 8-10 hour day if you are crafty with a wrench and wiring.
You have alot going on there. Gonna hafta pull the tank, Extend and Run the longer wires through the bars to the plugs, Two front brake lines to replace and bleed, Throttle cables are 4 minutes so that no biggie but looks like those pipes are gonna hafta come off the bike to replace yer' clutch cable. Make sure you have a big set of C-Ring pliers and a new gasket for that clutch cover and you should get new exhuast gaskets while your at it.
Its a project for sure. Just did mine and took my time on it. Indy shop would probably want $400 maybe $500 bucks to do it so if you can wrench?
If not so crafty it could easily stretch into a second day.
Old Jul 27, 2009 | 10:10 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
The drag bars will probably still give you best control for due to their design. I like drag's, but those drags look killer on their. You are suffering from tmf (too much forum!)
Ranger Rick
Nov 24, 2017 01:12 PM
rebelpiper
Sep 21, 2012 08:07 AM
KevH
Jun 7, 2012 03:23 PM
Foodog2
Mar 20, 2012 07:56 PM
McGillicutty
Jan 4, 2007 10:22 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
