This was scary - dna wheel
Old Jul 27, 2009 | 06:15 PM
oct1949's Avatar
oct1949
At work (GM) on machine building we used the industry standard of having at least the same amount of thread depth as the Dia of the bolt..
So A 1/2 dia bolt must have at least 1/2 in of threads in the tapped hole to hold properly.
3/8", 3/8"of threads in the hole..ETC.
Old Jul 27, 2009 | 06:29 PM
anubisss's Avatar
anubisss
I just double checked mine. Tight as can be. Sorry for your problems.
Old Jul 27, 2009 | 06:45 PM
Tx_Outlaw's Avatar
Tx_Outlaw
I always thought it was 2:1 in a blind hole and 1:1 for a nut/bolt combination.
Old Jul 27, 2009 | 07:09 PM
vulcanater's Avatar
vulcanater
Originally Posted by joshh
finally got to ride after doing a 200 conversion on my '02 softail and after 50.1 miles my ride made a hell of a noise and vibration. i came to an abrupt (but safe) stop to find that my rear sprocket had come out of my wheel hub!!! looks like some of the new bolts came loose and the rest pulled right out of the billet hub. this was a brand new DNA spoked wheel with a chromed billet hub that i bought from american classic motors. bolts used were new high-grade and were torqued to harley spec with a recently calibrated snap-on torque wrench and had red lock-tite (stick type - that sat for a week due to bad riding weather). no help from american classic motors or DNA. they dont even call back. sent the wheel to a machine shop to have 5 new holes machined into hub and guess i'll try again... any suggestions??
Damn Joshh,
That sucks! But I'm glad you are OK. That could have really been a bad deal! I'd keep calling and emailing DNA till I got in touch with some one. See what they have to say about it.
Chop On,
Robert
Old Jul 27, 2009 | 08:23 PM
rbabos's Avatar
rbabos
I guess the main question would be , how much thread was left that didn't strip out, or could have been made use of for more holding power? Sounds like you did everything right but the bolts were too short. The above posts for thread area are good for metals of equal composition. Steel bolts in aluminum threads need more thread count to equal out, unless you use helicoils. Then it's pretty much steel- steel again.
Ron
Old Jul 27, 2009 | 08:31 PM
WARG's Avatar
WARG
Were you running a DNA pulley? I have read that the bolts that come with the DNA pulley's are actually too short and you need to purchase longer chrome bolts to account for the spacer. Maybe you used a bolt that was too short? Just offering ideas. Good luck.
Old Jul 27, 2009 | 09:54 PM
JY Kelly's Avatar
JY Kelly
Jesus, I'm just glad you came to a stop- UPRIGHT!
Old Jul 27, 2009 | 10:22 PM
Dustmaker's Avatar
Dustmaker
Checked mine, and all is good!
Sorry to hear about your misfortune. Glad to hear you are Ok too!
Old Jul 27, 2009 | 11:22 PM
gabadoo's Avatar
gabadoo
Hrmm Interesting. I myself did a similar conversion, and had a pulley issue. I was in daytona for Bike Week, and had another fellow come up from behind and said that my pulley was wobbling. Sure enough, 2 bolts had backed out, and 1 of them was extremely close to colliding with the swingarm....bad news. The bolts that I received were too long, for the new pulley which seemed to be narrower near the hub, versus the factory one. I had to grind them down until they cleared. I torqued them ****'s down to spec and put on the red loctite and haven't had a problem yet.....
Not to highjack this thread, but can anyone tell me if by re-torquing the bolts as a check before a long ride, am messing with loctite settlement and making things worse?
Thanks, and as a precaution I ALWAYS visually check the pulley... call me paranoid.
Old Jul 27, 2009 | 11:50 PM
anubisss's Avatar
anubisss
Joshh, I live near DNA so if there is anything I can do to help you let me know. Take some pics and I can ride down there and show them and see what they say. Just let me know.
