Se 204 in a bone stock 96"
Old Aug 5, 2009 | 11:15 AM
  #31
oct1949's Avatar
oct1949
Originally Posted by Archer1968
This may help SE 204 Cam Kit Part Number 25464-06, you will also need a Cam install kit 17045-99c. this will fit the 08 96".
Anything above 204 cams will need head work. those 255's definately need head work, there monsters.
Very broad statement, almost any cam will do better with head work, but it has to be done for the build, not just do something and throw it on..
the SE 255 are not Monster cams, there have a purpose and were made for heavy touring bikes wanting down low power and that is what there good at. Most dnyo sheets that I have seen with them tend to fall off the table at 4k.
The 103 kits installed by most dealers have flat tops, SE255's and stock heads.
In heavy touring bikes there great, but most lighter bike riders will usually not be happy with this setup. they just peter out to soon.
Old Aug 5, 2009 | 11:20 AM
  #32
GunmetalBlueNT's Avatar
GunmetalBlueNT
Originally Posted by oct1949
Time has proven the woods cams will win hands downs with there fast ramp angles .. There a lot More $$$, but they do perform, some think they are noisey, but most overlook that..
When I beat our 1/2 of my brains decieding which cams to put in I used the below site to help me deciede which cam to get. they show all the numbers so U can make a really good choice.
www.bigboyzcycles.com/tccams.htm
U can compare most all the cams on the market side by side with this program
and it lets U put 3 different cams on the screen at a time..
Though I do like a few Woods grinds, I would never say they are the best by far. They are a single profile/simple linear pattern grind(which in many cases does work well). Alot of the newer and better grinds use an advanced profile design though having a slow intial opening of the lobe to increase air velocity giving better low end torque, then opening up real fast to allow increased air volume at the higher rpms extending the powerband. Only a handful of shops employ these type of grinds. I myself went fom 3 different wood cams(which for the most part gave real good results)to a new custom one off grind for my bike using and advanced profile lobe. I gained a wider powerband which equals better cylinder fill at all rpms.
Old Aug 5, 2009 | 11:36 AM
  #33
oct1949's Avatar
oct1949
I agree, I also did't say they were the best.
Only stated that in here and in other forums, most, not all builders and Bros in the know, that are looking for top performance usually recommend and use Woods cams for getting the big numbers.
One thing I've learner over the yrs is, seldom, one product the best. Maybe for certain applications but not for all..
Old Aug 5, 2009 | 11:37 AM
  #34
WATERHAWG08's Avatar
WATERHAWG08
Man, I'm getting a wealth of knowledge from the thread. Anyone with cams, where to buy them and/or tools.....keep the posts coming....thanks
Old Aug 5, 2009 | 08:21 PM
  #35
z edge's Avatar
z edge
Ohh my God yes...
I've heard both of Called to Duty's bikes, Both his 07 Deuce and 09 NT and they have A great rumpity-rump, sound at idle.
Of course its still a TC 96" and they Idle faster than the 88's even, but the 204's sound BADA$$ compared to a Stock cam in the 96" U won't be dissapointed.
Its A lot more than my andrews 26h's & they sound a little better than stock, but not like the SE204's..
Don't forget to Look at the THREAD ["DYNO" number for SOFTAILS], Its A sticky thread, at the top of page 1 in this softail section.
It has dyno sheets and or munbers of different motors builds with different cams.
The Touring section also has a dyno area, They have a lot more postings (over a thousand) than our Softail area.
Thanks, that's what I was waiting to hear. I like the sound of a good cam in Harley. This sounds like a good and simple upgrade.
Old Aug 5, 2009 | 08:43 PM
  #36
GunmetalBlueNT
Just be aware that a twin cam will never have the EVO/Shovel sound. And another heads up, both the TC 96" and TC88" have both the same 1050rpm idle.
Old Aug 5, 2009 | 09:39 PM
  #37
smileyjoe's Avatar
smileyjoe
please forgive me for the dumb question, but is there no way to get the idle down on the newer bike's ?
Old Aug 5, 2009 | 10:27 PM
  #38
GunmetalBlueNT
No, you drop the idle and your engine doesnt get enough oil to critical areas of the engine.
Old Aug 6, 2009 | 03:45 AM
  #39
stupid_rope's Avatar
stupid_rope
Anyone using Headquarters Hurricane cam?
Old Aug 7, 2009 | 11:13 AM
  #40
HarleyWood's Avatar
HarleyWood
Thats an accurate description of the 255's IMO. I put them in my stock 96 with just stage one upgrades (AC, pipes, PCV&AT).
bought the PCV from FuelMoto and let auto tune dial it in. It brings in a bunch of power down low where I want it, I very seldom venture over 4K.
With the 255's in my ultra I can pull out to pass a truck and roll on from 65 or 70 and be doing a 100 before I pass the nose of the truck. On the back roads and hills where I normally ride in 4th or 5th gear it just eats up the road by twisting the wick, no need to down shift because it falls out of the power band.
I like'm
