Thanks for all of the advice. I want to take the tank off completely to allow room to remove the tunnel guard (black plastic piece) as stated by m i k e or someone in an earlier thread.
I have a decent idea for fuel guessing after this last trip....I dont trust that gas light when it goes on that much nor the "range" guesser....had it on 20 miles and had about 10 miles to go (freaked out and put some gas in it...trying to leave it empty for the tank lift).
Question for m i k e - did you have any probs with any electrical stuff or speedo?
Thanks all
no & if i did it over or if i do i will run crossover through black plastic
housing for a cleaner look.good luck post up some pics along the way
& get ready for the infomous rattle at high rpm LOL j/k
Thanks. Im sure I will figure the crossover and plastic thing once I get started....not for another 2 weeks, I gotta go to Alabama for work stuff. I will definitely post up some pics once I finish my fender. Found a guy out at Deals Gap that will pinstripe and paint my rear fender for $100!! he has a booth out front and looks like he has been there for awhile...if anyone reading this has any experiences with him please pass it on.
Its possible you'll need to extend some wiring for a 3" lift. Although I didn't extend wiring for my 3" lift, I did reroute the last couple inches of the harness below the tank to gain the added length needed. That's a much less labor intensive option that extending wiring.
Adding to Mike's comments about improved looks, it is also reported to improve airflow around the heads. Always a good thing on an air cooled bike, no matter how small the improvement may be.
wonder why
i think it makes the bike look better
the negative is the fuel lite but who cares
i know how far i need/have to go
like idea of 3 people doin the job,
i explained it the way i did cuz it was part of takin
tank off anyway for my apes good luck dude
yeah the fuel thinng bugs me a bit but its more that I dont think it will suit my bike with the bars I have...& I'm saving to change out the front end at the mo,
I thought I had read in some earlier post respective to a Rocker tank lift, that you could install the 2" lift kit and keep the stock handlebars AND the turn signals. That just don't seem possible.
When I look at the handlebar/turn signal clearance to the top of the tank in the stock configuration, it's like maybe 1/2"
For whatever its worth I liked the look but have taken the kift back off because I put Apes on the bike and they hit. Plus I like the tank sitting low with the Apes, makes them look higher.
x2 and i didn't like the exposed wires and empty space were the tank boot was.
Is that BS?
I think so.... I did a 2" lift but moved the turn signals to the forks. Those signal lights would hit the tank for sure.
