Tank Lift
then take seat off,loosen back bolt(or just take out),
then release quick disconnect gas line,then prop tank
wait nevermind all that just go for a long aarse ride run out of gas
then syphon out rest,ok after all that get towels/somethin to drain that little exess
gas into when you cut crossover,drain the rest.i suggest painting
all hardware to match bike (cleaner look),install kit use blue loctite on hardware
im sure i missed some thin good luck
Now if you want to remove the tank do the above to include the following.. Remove fuel line to EFI its a coupler so push upward and pull down on the line.. Disconnect vent tube up front (1/4) rubber hose). Disconnect wire harness under tank once its lifted of the back bone... and ibeleive your are done.. If i missed a step, some one will chime in.. Good Luck
Yes this will throw off your fuel gauge slightly but they never really work well anyway. Your best friend when determining fuel consumption and when to get gas is the trip odo.
I'm sure it would be easier with more than one person but I did mine solo without too much trouble. I removed the tank but it was because I was doing a bar swap in conjunction with the tank lift and had to extend internal wring. If you do not remove the tank, make sure you loosen the rear tank mounting bolt or else you will bend the tank mounting tab back there when you try to lift the tank up.
Biggest pain, even after running the tank to near empty, is fuel run out when you pull the crossover hose. If you plug one end of the replacement hose and have a plug handy for the old hose end when you pull it off, you can quickly swap one side and then the other with minimal spill. Of course remember to slip new hose clamps over hose before you attach it to the tank. Unfortunately, no way to do this with tank off the bike since crossover hose goes under the backbone.
Last note is wiring aesthetics. You may end up with some exposed wires where shrink tubing pieces consolidate. This junction point is normally hidden by the tank console and that rubber boot/seal at the front of the tank but now will be exposed. If you are a stickler for attention to detail you can cover this with black tape or some other covering.
i think it makes the bike look better
the negative is the fuel lite but who cares
i know how far i need/have to go
like idea of 3 people doin the job,
i explained it the way i did cuz it was part of takin
tank off anyway for my apes good luck dude
I thought I heard that the speedometer wire works on the 2" lift, but has to be extended on the 3". If you do a search, you should be able to find more info on this.
Like everyone else stated, the fuel gauge to me isn't a really big deal. I typically know how far I can go on a tank of gas. If anything, I don't let the tank get too close to empty and probably fill up more than I did before the tank lift.
