Sob!
Old Aug 9, 2009 | 09:57 PM
oct1949's Avatar
oct1949
both indy's here will do it if not in the side.. use a t type plug or patch from inside.
U gotta feel right.;
Old Aug 9, 2009 | 11:57 PM
FLSTC4ME's Avatar
FLSTC4ME
So you say the shops would do that? I've been hearing some guys at work say they won't patch/plug tires.
Old Aug 10, 2009 | 12:18 AM
Mark g's Avatar
Mark g
I'd be buying a new tire. My piece of mind is well worth the cost! I'll be damned if I'm gonna go down because I was to cheap to buy a tire.
Most motorcycle shops won't even plug or patch ,as it is a major liability issue. if you notice most shops don't even stock plug kits anymore...
but that's just me....
Old Aug 10, 2009 | 04:02 AM
Rocker_Dan's Avatar
Rocker_Dan
nope.....
Old Aug 10, 2009 | 04:14 AM
jimmers1817's Avatar
jimmers1817
Using patches and plugs for over 35 years and have never had a failure. Never heard of anyone else having one either. Worse case you get a leak, just like you most likely did with the nail puncture. Not a catastrophic failure or sudden loss of air.
Personal choice but I'd be hard pressed to throw away a new tire with nothing more than a nail hole in it. Patch and new tube for me.
Old Aug 10, 2009 | 04:42 AM
FLSTC4ME's Avatar
FLSTC4ME
Thanks guys!
Old Aug 10, 2009 | 10:47 AM
maddbomber's Avatar
maddbomber
i just had the same dilemma....ive had my bike for a lil over a week and some ******* slashed my front tire (on the tread).....i did not want to have to worry about a patch leaking air and getting stranded an hour away from home so i bought a new tire....and a tube.....
my bike is garage kept and rarely sits out...what a dick move
Old Aug 10, 2009 | 11:40 AM
tk353's Avatar
tk353
back tire clean hole i would plug it with rope plug kit. front tire i would remove it and take it to indy and get patched
Old Aug 10, 2009 | 04:18 PM
Rail's Avatar
Rail
Exactly what I would do/have done.. The rope plugs work just fine in the rear tires but can cause a balance issue in the front, hence patch the front.. I've patched a lot of small holes over the years and never had a problem.. I damn sure wouldn't throw away a brand new tire.. All this is assuming the hole in in the tread and not in the sidewall.. Sidewall is a different story..
Old Aug 10, 2009 | 05:20 PM
tk353's Avatar
tk353
and if you really dont want the tire let me give you my address and you can send it here
