Cable lengths for 13" apes on 04' Fatboy?
Old Aug 10, 2009 | 02:28 PM
Nickrc3's Avatar
Nickrc3
Default Cable lengths for 13" apes on 04' Fatboy?
Hey Guys,
I realize this subject has probably been repeated dozens of times, however, I hate to screw up the measurements (too long and/or too short) regarding new cables for 13" ape hanger bars on my 04' Fatboy which I intend to install soon. Stock riser height.
I'll be ordering the Magnum "sterling chromite" types - throttle, idle, clutch and brake line. What would be your recommendation of cable lengths? I realize I could measure with string, wire, etc., but your testimonies provide that confident.
Thanks,
NICK
Old Aug 10, 2009 | 04:45 PM
BigMike17's Avatar
BigMike17
4 inches over stock length is what you'll need -
Old Aug 10, 2009 | 05:14 PM
Weevil's Avatar
Weevil
Originally Posted by Nickrc3
Hey Guys,
Thanks,
NICK
The rule of thumb I was told was to add 1 additional inch of length for every additional inch of rise over stock, and to add 1/2" for every additional 1" of pullback.
The stock FLSTF has a 7 inch rise and 11 inch pullback. Not knowing what your 13 inch apes have as far as pullback is concerned, and not knowing what routing your going to use once you go to braided cables, I'd advise +6 to +8 over stock.
Old Aug 10, 2009 | 06:48 PM
BigMike17's Avatar
BigMike17
+6 or +8 over stock is way too much cable for 13" apes on stock risers...you'll have excess cable all over the front end. Even with the pullback you should not need that much. I'm running 12+ stock on my 20" bars with 4" riser and ran 8+ stock on 16" bars on 4" riser...
Old Aug 10, 2009 | 09:20 PM
Nickrc3's Avatar
Nickrc3
Thanks for the input guys.
I purchased the handlebar/controls/switches/wiring combo from Demon Cycles today. They're 13" apes with a 10" backward sweep and 34" wide @ handles.
I called Wild One and the gentleman mentioned +4" for clutch and +6" for brake and throttle - for use on their 14" apes w/ stock risers. I haven't compared the Wild One sweep setbacks to Demon's bars yet; however, these measurements given are consistent with other installations throughout the forums.
I may mount the bars this weekend to achieve a more accurate reading of the desired cable length.
Any other suggestions are greatly appreciated.
NICK
atxfxdb
Mar 2, 2014 08:53 PM
SSMNightTrain
Jun 2, 2012 07:47 PM
Mouth
Mar 12, 2012 03:23 PM
AussieTX
Jul 25, 2011 09:51 AM
schumacher
Jan 18, 2009 11:11 AM
