Oil drain plug location?
Old Aug 20, 2009 | 07:30 AM
jknowlton's Avatar
jknowlton
This might help, since the first few emails sound like they came from HD reps or salesmen. We all know the manual is great, but that is why the forums are here, to help others out:
http://www.dudeworld.com.au/HOWTO.ENGINE.HTML
Shows pictures of location of the oil drain plug. Replaced the o-ring, part number I believe is 11105.
Old Aug 20, 2009 | 08:35 AM
elvis8310's Avatar
elvis8310
That is what I was looking for. Now I can have him back on the rode soon as DMV opens to get his plates and Reg.
Old Aug 20, 2009 | 08:39 AM
jknowlton's Avatar
jknowlton
Good. Hopefully no major issues. Check the threads on where the drain plug goes. New drain is only a few bucks..also comes with new o-ring.
Old May 14, 2019 | 07:14 PM
Angie Mavis's Avatar
Angie Mavis
Stage I
Originally Posted by Mark R
look at the bottom of the frame under neath the oil tank, it is near the rear leg jsut in front, it is a hex head bolt 5/8 socket and has a allen key fittin inside asweel
the gear box drain is up under between the 2 shocks, it is also a 5/8 headed bolt
the primary drain is located at the rear, jsut under the derby cover, it is a torx fittin
Thanks so much for the easy explanation!! Found it right away!!!
Angie
mrtac2man
Aug 5, 2010 07:22 PM
CrossBones79
May 20, 2010 07:55 PM
Beerninja
Oct 3, 2009 07:11 PM
BigDeuceDoty
Oil Archive (no new posts)
Aug 4, 2009 03:54 PM
MikeGV
Apr 15, 2006 10:22 PM
