How much oil
Old Aug 26, 2009 | 06:13 PM
PewterHeritage's Avatar
PewterHeritage
Default How much oil
Checked my oil today and it's down just about to the "add" mark...would this be about 1/2 quart? Going to stop by the local indy tomorrow and pick up a quart...only 2500 miles on her so I haven't had to add any yet. Thanks
Old Aug 26, 2009 | 07:51 PM
deadman77's Avatar
deadman77
Add enough to put it between full and add. It wont be much.
MikeM
Old Aug 26, 2009 | 08:17 PM
tmitchellof PG's Avatar
tmitchellof PG
Check your oil with the engine up to operating temperature. Shut the bike off and let it sit for a few minutes. Check the oil level when the bike is on the side stand. Make sure you don't overfill. You are better off with the oil a bit below the full mark then any above it.
Tom
Old Aug 30, 2009 | 10:14 AM
Road King Kid's Avatar
Road King Kid
Can someone explain the danger in too much oil? A few weeks ago, I was at the low level mark on the dipstick. The manual says that is about one quart low. I put in a half quart, ran it around the block, shut it down, let it sit for a few, checked the oil, barely any difference. Added another half quart, ran through the same excercise, and now it is well above the full line.
I asked around to see if I should drain some of the excess oil out. Was told not to worry as long as it less than a half quart over (probably bad advice). Yesterday, while riding down the freeway, the dipstick popped out and now the entire rear end of the bike is drenched in oil. I am guessing that too much oil leads to too much oil pressure? Is it possible that I damaged any other seals in the engine as well?
arod6
Oct 4, 2015 02:27 PM
Pale Horse Rider
Jan 15, 2015 12:05 PM
WideGlideFever
Dec 16, 2013 09:10 AM
fedfuzz79
Oil Archive (no new posts)
Mar 4, 2008 05:41 PM
Anthony8858
Oct 2, 2005 09:51 AM
