Just blast 'em... If you screw send 'em out for PC... lol
When you are wet sanding with 600 scotch pad or wet sand paper... use soapy water!
The soapy water will help to degrease it cause it may not look like there is a lot of grim but there is... you'll see when you start sanding... The sanding is the toughest part... Break open a six pack turn on a radio and go to town... I'm sure you be happy when you're done.
Good luck man, M
