help needed trans drain plug
Old Sep 2, 2009 | 03:00 PM
kalamitty's Avatar
kalamitty
Question help needed trans drain plug
on my heritage to save some money i decided to change my oil/filter myself no probs, but when i came to change the trans fluid, the drain plug seemed to have been overtightened by the last techi and the key started to turn with no effect, whats the best method of removing the plug i will get a new one to replace it, do i have to take off the trans cover and drill it out or is there another method any help thanks.
Old Sep 2, 2009 | 03:07 PM
story808's Avatar
story808
Hey bro first thing what year is your bike... and if it's a softail TC the drain plug is between the shocks under the bike, right... If memory serves me right it's a allen screw or you can use a 5/8 socket with an extension to reach it...
Are you talking about the cover where the clutch cable goes into? or to check or add fuild?
Old Sep 2, 2009 | 04:02 PM
2DAKERB's Avatar
2DAKERB
Before trying to loosen the drain plug put the correct allen socket into the drain plug with an extension and tap it with a hammer (not too hard) This loosens up that loc tite they use.
Old Sep 2, 2009 | 04:39 PM
oldgeezer's Avatar
oldgeezer
Break it loose with a 5/8" socket then remove it the rest of the way with an allen wrench. If your bike has an 88B or 96B engine, the drain plug will be between the shocks.
Old Sep 2, 2009 | 09:07 PM
deadman77's Avatar
deadman77
Mine works with a socket. Forget that allen head nonsense.
MikeM
Old Sep 3, 2009 | 12:53 AM
kalamitty's Avatar
kalamitty
its a 05 model and the drain is under the derby cover its a sunken torx screx and the key just turns and don't grip.
Old Sep 3, 2009 | 03:05 AM
PurpleHaze's Avatar
PurpleHaze
Sure its not a 1/4 Allen wrench?..also,I think you may be refering to the primary drain plug...good luck...
Old Sep 3, 2009 | 05:57 AM
boosteddelslow's Avatar
boosteddelslow
Your trying to drain the primary not the tranny. On my bike the primary drain plug is the same as the tranny plug. Allen wrench internal and hex head external.
Old Sep 3, 2009 | 06:45 AM
J-Train's Avatar
J-Train
I saw you have an 08 night train. Hopefully you might know, but I have an 04 night train FXSTBI, is the primary plug the same as the tranny on an 04 night train? I can only locate two plugs underneath my bike?
Old Sep 3, 2009 | 07:12 AM
o/d's Avatar
o/d
on my '02 fxst the primary drain plug is located near the rear of the outer primary cover.
it's almost like a set screw(no head) & either hex or torx drive(i forget which).
as mentioned, the trans drain is located between the rear shocks. it's hard to get a good look at. i just go by feel. also as mentioned, that plug has a hex head & hex drive.
i recommend a service manual.
