Hard shifting issue
Old Sep 3, 2009 | 08:26 AM
Beachman's Avatar
Beachman
Default Hard shifting issue
I'm a new rider. I purchased a 08 fat boy a month ago. When I put the bike in 1st gear at an idle it is not smooth. It seems like there is a clanking sound. Is this normal?
Old Sep 3, 2009 | 08:59 AM
aviscomi's Avatar
aviscomi
I assume that this is your 1st Harley...welcome to the world of "clank" this is normal. When you change your tranny fluid try using Redline Shockproof, this will help a little.
Old Sep 3, 2009 | 09:07 AM
FastHoss's Avatar
FastHoss
It can be normal.I would be sure primary adjuster is working correctly,loose primary chain can clunk extra hard.Also helps to work clutch in and out a few times while warming up to seperate the cluch plates.
Old Sep 3, 2009 | 09:08 AM
screamn_eagle's Avatar
screamn_eagle
yep, its normal....no worries, your tranny won't fall out. just get on and ride!!!
Old Sep 3, 2009 | 09:09 AM
mke125125's Avatar
mke125125
yep,what he said. when my bike is cold it gives a pretty good clunk when going into first. but after riding and getting the tranny fluid slapped all around in there it gets better. swap the fluid to a quality syn. gear oil at the first service. that clunk is kind of a harley trade mark.
Old Sep 3, 2009 | 11:16 AM
09tail''s Avatar
09tail'
Every harley I've ridden has done that, especially within the first few miles until everything has heated up...still does it after that, but not as hard of a clunk.
Old Sep 3, 2009 | 11:45 AM
XARAN's Avatar
XARAN
A certian amount of "clunk" is normal with a HD. Try changing to Redline V Twin Transmission Oil it helped quiet my trans also sometimes if you go from neutral to second and then shift to first before moving it is less noisy.
Old Sep 3, 2009 | 12:10 PM
JKMWELDER's Avatar
JKMWELDER
I have an 06 FatBoy and it has done that every time I fire it up after it has cooled down. Not as bad as when it was new but still there. If your not comfortable about the sound take it in to the dealer I'm sure they can help explain what is going on and put your mind to ease.
Old Sep 3, 2009 | 12:37 PM
Beachman's Avatar
Beachman
Good info. Thanks for all th e response.
Old Sep 4, 2009 | 06:47 AM
tk353's Avatar
tk353
I use Bel Ray for the trans and no wine or clank and I can find neutral. I use Motor Factory® Primary Case Lube in the primary. because Amsoil has gone up so much I just switched to Mobil 1 for vtwin and it works as good. I have 39,000 miles in about 2 years and it runs great and no debris in the oil changes.
http://www.belray.com/consumer/product.fsp?pid=13637
http://www.customchrome.com/dcm/cc/view.asp?mfoil.html
kustom78
Aug 28, 2012 09:02 PM
37sportster
Apr 25, 2012 12:20 PM
IronBoy883
Mar 16, 2012 10:11 PM
MoonCricket
20
Aug 9, 2010 01:28 PM
KBES BAGGER
Oct 15, 2005 01:36 PM
