gear ratio
Old Oct 12, 2009 | 03:53 PM
RHillbilly's Avatar
RHillbilly
Default gear ratio
any body changed the sprockets to change the gear ratio,my Fatboy has 32 trans 66 rear I am thinking about changing the trans to a 30 so it will pull better on takeoff this thing will cruise at 100mph in 6th no problem but by changing sprockets maybe I can use 6 gear under 75 or 80 mph
Old Oct 12, 2009 | 04:56 PM
DECON BLUE's Avatar
DECON BLUE
Thumbs up
What year is your bike??? What size is the rear tire??? I went from a 200/55/17, to a 200/50/17 and it changed the overall gear ratio because of the shorter rear tire to where 6th is much more useable and 3rd and 4th are great around town bar hoppin! Plus it lowered the rear too.
Old Oct 12, 2009 | 05:53 PM
JRK5892's Avatar
JRK5892
i put a an andrews 30 power pulley, barnett clutch spring, and baker IP bearing in my dyna... it is AWESOME! i love it!!!!! well worth it!
here are some pics from the install... used tools from Georges garage... they worked great!
Old Oct 12, 2009 | 11:17 PM
oct1949's Avatar
oct1949
I just did cams this spring and with them it pulls 6th now easy at 60, better or the same as 5th used to be around 50.....
And fuel mileage improved with them....
FLS103
Aug 12, 2016 10:37 PM
Next In Line
Sep 28, 2015 11:17 AM
cowboyfxst
Jun 21, 2007 01:15 PM
MAX EVO
Jan 17, 2007 01:16 PM
fiddledicksr
Nov 8, 2006 01:37 PM
