help with punyness
Old Oct 16, 2009 | 08:45 AM
DECON BLUE's Avatar
DECON BLUE
Question
Yea, what end caps??? Mine don't have no stinking end caps.
Old Oct 16, 2009 | 08:51 AM
hdspringer02's Avatar
hdspringer02
I think all short shots have end caps on them. I still can't figure out how to take mine off though. Anyone know if there is a screw that needs to be removed? I tried the WD40 and needle nose trick, but no luck so far.
Old Oct 16, 2009 | 09:04 AM
1931jamesw's Avatar
1931jamesw
There should be an allen head screw on the backside of you pipes near the ends of them.
Old Oct 16, 2009 | 09:07 AM
1931jamesw's Avatar
1931jamesw
Didnt thiat kill your performance? I tried that and it did sound better except the funky sucking air back in the pipe sound on deceleration and the bike had way less power due to no back pressure on the exhaust.
Old Oct 16, 2009 | 09:24 AM
hdspringer02
Thanks! I was able to remove 1; it looks like the other screw may be stripped. So are the baffles attached to the end cap?
Old Oct 16, 2009 | 09:30 AM
1931jamesw's Avatar
1931jamesw
Yes. Its that perforated looking metal that slides up in the pipes that is attached to the end cap.
Old Oct 16, 2009 | 01:30 PM
hdspringer02
So it sounds like the pipes need to be removed from the bike so that the holes can be drilled for the new baffles?
Old Oct 17, 2009 | 06:49 AM
dkpawlowski's Avatar
dkpawlowski
OK
I guess you guys are calling the baffles the "end caps".
The baffles are one piece that slides in the pipe. Like a tube with slots in it.
If you order "baffles" from V&H that is what you get.
Old Oct 17, 2009 | 07:34 AM
1931jamesw's Avatar
1931jamesw
Originally Posted by dkpawlowski
OK
That is correct.
Old Oct 17, 2009 | 08:44 AM
hdspringer02
Can someone answer my last question?
