Sissy Bar medallion removal
blow dyer would work, but i like to use a heat gun. it is great for this kind of stuff and only takes a matter of seconds
Here are some pics:
1) Sissybar with medallion removed. Note the center hole for the screw that holds the backrest on, a hole on each side where the medallion was held by the 2 clips, and another off-center hole where the third medallion peg fit without a clip. You can see a slightoutline where the medallion used to be.
2) Concho and seat back in place now. I ran the center bolt through the stock hole in the leather strap, then through the stock hole in the leather rosette and into the back pad, then "tied" the concho as normal, which holds the new medallion in place. Concho looks great, almost hides the original holes, but not quite. I think MoCo just wants us all to buy new sissybars (which I'm not going to do) instead of changing medallions.
3) Here is the medallion and clips that were removed and discarded. If I ever want to replace it, Harley sells a number of adhesive medallion designs.
