Patina
Old Nov 11, 2009 | 08:55 PM
MetalMike's Avatar
MetalMike
That is where the abbrassive stuff comes in, it's a strange process cause your working on one area and then some drips to another area and makes darker drip lines. I use the abbrassive pad to scuff away some the dark spots and then try to blend it with what you already have going. i like to keep 2 different strenths one half/half and one a bit weaker so you can blend. It is very handy to keep clean water near with clean towel so if u get to where u want to be u can clean it with water and stop the reaction and retain the color. Hope that helped.
Old Nov 11, 2009 | 09:08 PM
MetalMike's Avatar
MetalMike
Then rub 2 coats of Staples crystal clear paste wax, buff off and it will protect from further oxidation and give it a nice wet but not to glossy look.
www.haleysdesigns.com
Old Nov 12, 2009 | 05:53 PM
C. Numb's Avatar
C. Numb
Thanks Mike! I'll give it a try.
Old Nov 12, 2009 | 07:01 PM
oct1949's Avatar
oct1949
kinda like browning the barrels on the muzzle loaders I used to build.. just have to keep at it to get the look U want.
Keep at it and U'll get where U want it...
Old Nov 13, 2009 | 06:22 PM
C. Numb's Avatar
C. Numb
I was at it again today, using your technique, smoothing it out with the rough side of the sponge. It is a long tedious process, because no matter how smoothly you sponge the agent on the copper, it always wants to bead up in the same places, so I constantly have to dry it. This doesn't give it time to make big color changes, so I had to do 30 or 40 layers, smoothing the copper out between each layer to get it to where I wanted it. It is very dark now. Almost black, but not quite. It's much more uniform now. Thanks again!
Old Nov 14, 2009 | 12:49 PM
MetalMike's Avatar
MetalMike
No problem C. Numb, just tryin to share the knowledge. Looks SWEEEET!!!
boosting1bar
May 8, 2013 12:11 PM
capitalist_slave
Dec 28, 2011 11:07 PM
bberck
Feb 24, 2010 09:22 AM
ickmak
Mar 16, 2008 08:37 AM
utz
Jan 25, 2007 12:13 AM
