Ignition coil ?
Old Nov 7, 2009 | 07:10 PM
huey408's Avatar
huey408
Default Ignition coil ?
Anybody have problems with 07 softail coils? Went to start the bike yesterday and had no spark so went looking through the service manual and checked the coil spec is 0.5-0.7 ohms I have 5.6 ohms. Called 2 local dealers and neither had one in stock was looking online and seen the part number has been superseded. So just wondering if this is a common problem and if anybody else has had to replace theres.
Old Nov 8, 2009 | 08:04 AM
tk353's Avatar
tk353
only thing i had to change was the cheap plug wires. i went to the screamin eagle and they start and run much smoother
Old Nov 8, 2009 | 07:22 PM
huey408's Avatar
huey408
Were u getting no spark with the stock wires ? If so I will have to check that way, I never checked at the coil I only checked at the plug end of the wire.
Old Nov 8, 2009 | 08:22 PM
oct1949's Avatar
oct1949
Iam not great with ohm meters, but are U sure u had the right setting...The 5.6 reading U got if not set correct could be .56ohms. Just wondering if so it would be within specs.
Old Nov 8, 2009 | 09:04 PM
huey408's Avatar
huey408
No I had 5.6 but I think I was testing it wrong. I was testing terminal to terminal.
Darin Edwards
Sep 18, 2015 01:45 PM
Shackleford
Aug 21, 2014 08:51 PM
Iron Man73
Ironhead
14
Sep 30, 2013 08:44 PM
kcoughenour
EVO
30
Jan 2, 2012 03:46 AM
zaxcar
EVO
Oct 13, 2009 06:50 PM
