Cross Bones Oil Capacity
Old Nov 9, 2009 | 09:39 AM
BadDog20DU's Avatar
BadDog20DU
Stage IV
Default Cross Bones Oil Capacity
Does anyone know why H-D increased the oil capacity stated in the Service Manual for the Cross Bones from the 2.5 wet/3.0 dry in 2008 to 3.5 wet/4.0 dry in 2010? H-D swears there was no change in the actual capacity and there was just a "wording change" in the manual, but changing the capacity numbers by 1 quart is not a simple "wording change" as I see it. The two manuals do not state the same thing in different ways, they state different things. So, did H-D take a manual that was correct and change it to be wrong or did they change the capacity and then decide not to tell anyone why and to deny that they did it? I can't get a straight (or a consistent) response from the Motor Company so I thought I'd see what you guys know about it. I know on my 2008 I put in 2.5 quarts on an oil change and the level is right where it is supposed to be. Has anyone done a change on a 2010? If so, how much did you add to get it to the full mark?
Old Nov 9, 2009 | 11:58 AM
silverbiker41's Avatar
silverbiker41
ive been pulling my hair out trying to figure out how i over filled my 09 when i changed the oil this may explain alot
Old Nov 10, 2009 | 05:16 AM
BadDog20DU's Avatar
BadDog20DU
Stage IV
Default Doing the math......
So maybe the Service Manual tells dealers how much oil to charge you for (3 or 4 quarts) rather than telling owners how much oil to put in (2.5 quarts)?
Old Jun 9, 2012 | 02:04 PM
CRISSBONES's Avatar
CRISSBONES
5th Gear
I have inherited an '09. Had the 1k change, but think I will change myself with amsoil. How much are you guys dumping in?
Harley says 3.5 on their website.
http://www.harley-davidson.com/wcm/C...S&model=flstsb
Thanks!
Old Jun 9, 2012 | 02:33 PM
NoRegerts's Avatar
NoRegerts
Thanks!
WOW! Old thread.
Amsoil is great. I use it too. When you drain your oil and install the new filter, the bike will take about 2.5qts. Add 2 to start then check the dip stick while the bike is on the side stand. It should read about normal, if not add a little more until it does.
Fire up the engine for 30sec to a minute, then check again. I've never needed more than 2.5qts during a change. Don't over fill it, you/ll send the dipstick flying out along with nice hot oil all over your leg.
Old Jun 10, 2012 | 07:31 AM
CRISSBONES's Avatar
CRISSBONES
5th Gear
Perfect! Thanks!
stonewall1998
Apr 18, 2017 08:05 PM
Rus103
General Topics/Tech Tips
Jun 15, 2014 06:33 PM
johnb3207
Apr 26, 2013 07:16 AM
sonar_chris
Oil Archive (no new posts)
19
Jan 23, 2008 03:46 PM
acadien
Jul 25, 2007 12:50 PM
