oil change
Old Jul 25, 2007 | 04:19 AM
acadien's Avatar
acadien
Default oil change
Gents
Just did an oil change should I check the oil level with the dip stick screwed all the way in or just sitting on the hole.Also do you do transmision and primary every 5000 K same as motor or every 2 motor oil change.
Roger.
Old Jul 25, 2007 | 05:32 AM
jbhawley's Avatar
jbhawley
Default RE: oil change
spend the 40$ and get a service manual...
all your questions will be answered.
Old Jul 25, 2007 | 05:44 AM
tizone's Avatar
tizone
Checking oil info is in the owners manual. Screw it in. Check the manual for proper readings.
[sm=icon_rtfm.gif]
Old Jul 25, 2007 | 05:58 AM
acadien's Avatar
acadien
Thanks I got the service manual but the instructions were not clear I checked the oil with the dip stick scewed all the way in it should be good I put in 3 1/2 litres in.
Old Jul 25, 2007 | 08:22 AM
SIM's Avatar
SIM
ORIGINAL: acadien
What the hell is a litre? you have to convert for some of us rednecks.
Old Jul 25, 2007 | 09:08 AM
norskehd's Avatar
norskehd
Engine oil - check with the dip stick screwed in
Transmission - check with the dip stick resting on the treads (screwed out)
If you changed oil only and not the filter you will need only about 3 quarts for the engine.
I put a couple of boards under the jiffy stand so it is sitting straight up when I change the fluids.
2007 Electra glide classic - pewter pearl.
Old Jul 25, 2007 | 12:50 PM
acadien's Avatar
acadien
Litres = little bit less then a quart sorry canadian measurements.Are gallons are bigger thow Lolll!
Crazy
Jun 27, 2017 07:43 PM
johnb3207
Apr 26, 2013 07:16 AM
skully1200
Jun 5, 2011 07:35 PM
DanielBoone
Sep 25, 2007 07:11 PM
07streetbob
Dec 26, 2006 10:05 PM
