Deluxe riser help!!
Old Nov 19, 2009 | 09:21 PM
huff_custom's Avatar
huff_custom
Default Deluxe riser help!!
I got a question? My nieghbor has a 05 softail deluxe and im putting 16" apes on it. He wants short risers and i was wondering if the softail deluxe risers are like the fx and xl risers intercangable. If not does anyone have a picture of a set or can lead me in the direction of where i can find a short set for a deluxe. Thanks
Old Nov 19, 2009 | 10:03 PM
SEDELUXE's Avatar
SEDELUXE
the fat boy has short risers you will need the entire set up.
both risers and the top piece. or go to custom chrome catalog and order from there.
so the answer is yes they are interchangable if you have all 3 pieces or some times 4 pieces
Old Nov 20, 2009 | 03:30 PM
Kdavid's Avatar
Kdavid
The Deluxe top clamp only works with the Deluxe risers. So as mentioned above you will need short risers and matching clamp.
Old Nov 20, 2009 | 08:03 PM
Mike NY's Avatar
Mike NY
I used a set of White Brothers 1.5" Chubby type Risers.
Wild 1 sells thems as well. WO525
http://www.wild1inc.com/order_risers.html
Also be sure to change the Riser Bushings to Poly otherwise those bars are going to move too much.
Of course the stock Deluxe Top Riser clamp can't be used.
Mike
Old Nov 21, 2009 | 04:08 PM
kong88122's Avatar
kong88122
Stage II
anything off heritage will fit your delux, risers bars, cables
Old Nov 21, 2009 | 04:17 PM
anubisss's Avatar
anubisss
Get rid of the deluxe risers with the bend in them.
lorax808
Apr 12, 2019 08:38 PM
The Silver Viking
Oct 4, 2015 06:49 AM
harley57
Jan 4, 2010 06:36 PM
Kdavid
Jun 27, 2009 09:33 AM
anubisss
Nov 27, 2007 08:05 PM
