Removing fuel pump from Deuce tank?
Old Nov 27, 2009 | 08:56 AM
Dieselhed's Avatar
Dieselhed
Default Removing fuel pump from Deuce tank?
Here's what I've got. Doing a tank swap. My manual says "reach inside the tank (yeah right) and push the fuel pump housing to disengage it from the end cap." It doesn't say which way to push it, forwards or back. I cannot get my hand in to get a good push on it so I used a new paint stir stick and pushed both ways. This thing will not budge forwards or backwards. What the ^$%@ am I doing wrong?
Old Nov 27, 2009 | 05:08 PM
stro1965's Avatar
stro1965
It takes a pretty good push to unsnap it. If you use a flashlight you may be able to see where it is hinged.
Old Nov 27, 2009 | 05:14 PM
stevelonewolf's Avatar
stevelonewolf
You'll have to use your hands. That housing is plastic and you have to be careful. It slides down two metal posts attatched to the bottom of your tank. I have big hands and it aint easy. Good luck...
Old Nov 27, 2009 | 06:46 PM
Dieselhed's Avatar
Dieselhed
Got it with a paint stir stick.
digthemlows
Jul 6, 2015 04:31 PM
Alain
Apr 30, 2015 06:33 PM
Hot Rod King
May 6, 2011 07:20 PM
cabentz
Dec 29, 2006 09:26 PM
cabentz
Dec 25, 2006 05:47 PM
