brake caliper
Old Dec 6, 2009 | 09:29 AM
rodney123456's Avatar
rodney123456
Default brake caliper
i have a 2000 softail deuce when i put on the front brake it tends to pull to the right a little making it harder to keep your balance when somebody is ridin on the back. Is there anything you can do besides using the back brakes.
Old Dec 6, 2009 | 09:47 AM
I8SMK4U's Avatar
I8SMK4U
I don't think the brake is pulling it to the right. All those components are linear. When the brakes are applied it only works with those components. On a care one caliber may be stronger on one wheel than the other slowing a tire down more causing the vehicle to pull to the right or the left.
When you apply the brakes, Are there any new noises, any scratches in the rotor or does it all look like is working properly? Are you shifting your weight and bracing for the brake or are you loose?
Old Dec 6, 2009 | 10:34 AM
2003Springer's Avatar
2003Springer
Betting you have a blockage to the left side caliper. Check for compression of both sides when you are on a jack!
Old Dec 6, 2009 | 11:38 AM
rickb's Avatar
rickb
Dual calipers????
Old Dec 6, 2009 | 11:41 AM
rickb's Avatar
rickb
I would be checking the wheel bearings as it must be some how pulling on one side and the only thing that could be allowing it is a bad bearing on one side.
Old Dec 6, 2009 | 02:34 PM
I8SMK4U's Avatar
I8SMK4U
That would make sense, If a wheel bearing is going, and the brake applied, that would offset the axle off its "Linear Plane." Sorry, don't mean to sound like a math teacher.
Old Dec 6, 2009 | 02:48 PM
DECON BLUE's Avatar
DECON BLUE
Talking
+1 on the wheel bearing check. Duel front brakes on Deuce??
Old Dec 6, 2009 | 03:16 PM
Rockyriver's Avatar
Rockyriver
If front bearings check out OK, check the front forks individually with the front axle, wheel and fender removed. See if one can be pushed in by hand or jack more easily than the other.
Old Dec 6, 2009 | 04:18 PM
rodney123456
no just single brakes i dont know if is actually pulling to right or kinda wanting to fall to right i am trying to make sure i stop in a straight line it just seems to stop better as far as balance goes on back brakes than front brakes when i am ridin 2 up i am fairly new to ridin about 4 months.
Old Dec 6, 2009 | 04:20 PM
tlb's Avatar
tlb
Tell your passenger to lean to the left. 2000 model I would pull the wheel and check everything, plus drain and change fork fluid.
