Replacing inner primary cover w/chrome
Old Dec 8, 2009 | 01:51 PM
HD2005springer's Avatar
HD2005springer
Default Replacing inner primary cover w/chrome
Hello.
Has anyone replaced this... How difficult is it to replace the existing inner primary cover with a chrome unit? The HD dealer wants $330 in labor since its a 3hr job!! Any trick to the job? Is it straight forward - unscew part and replace with chrome. considering the oil and seals have oit be changed?
2005 Softail Springer
Thanks for the fedback!
Old Dec 8, 2009 | 02:46 PM
moondog99's Avatar
moondog99
Just buy a chrome cover and install yourself. Hell of a lot cheaper and looks great also.
Old Dec 8, 2009 | 03:38 PM
mimo's Avatar
mimo
Originally Posted by HD2005springer
Hello.
How mechanically oriented are you??? Do you have the proper tools? That piece would be a "no bolt on" in my skills because I don't have all the required tools... I wouldn't want to leave a "loose nut" in there.
Mimo.
Old Dec 8, 2009 | 04:01 PM
beaureed445's Avatar
beaureed445
$330 for 3 hrs labor? Jeez.....$110/hr? That's crazy talk!
Old Dec 8, 2009 | 05:24 PM
SpyderTB's Avatar
SpyderTB
i did my 3" primary install and IMO its easy. Just get a primary chain chock block and do it. If you really take your time it might take you 6 hrs. Either way just take it easy and feel good knowing that you did it yourself.
Old Dec 8, 2009 | 06:18 PM
Wallaby's Avatar
Wallaby
Did it on my Evo FXST, have to pull the clutch hub and the entire primary drive, big job. I had to do it when I snapped my rear drive belt, so chromed the inner primary when I had the chance.
If you want a chrome look, Kuryakyn and others make a 'bolt-on' chrome cover, it'll cost a lot less than doing it properly.
Old Dec 8, 2009 | 06:35 PM
niczumbo's Avatar
niczumbo
it IS a time consuming job but can be done with the rite tools(a good jack stand is an absolute!!) it took me about 4-5 hours and a bit of patience.getting the starter off was my toughest part.as for covers,ive seen em on bikes and i personally dont like the look.you could also check on indy wrenches in your area for prices .just my take on it
Attached Thumbnails Replacing inner primary cover w/chrome-mvc-801f.jpg   Replacing inner primary cover w/chrome-mvc-802f.jpg   Replacing inner primary cover w/chrome-mvc-803f.jpg
Old Dec 8, 2009 | 07:26 PM
2kids3pets's Avatar
2kids3pets
Here is a good read on whats involved in R&R the inner, I recommend you replace all the seals while you've that much apart
https://www.hdforums.com/forum/touri...need-help.html
Chrome inner is the ****
Old Dec 8, 2009 | 07:40 PM
fatusboyus's Avatar
fatusboyus
i have the complete chrome inner primary, and if i had to do it over again, i'd put on a cover in a heart beat
Old Dec 9, 2009 | 12:21 PM
HD2005springer
Thanks for the link... Great info... Doesn't look that difficult, just patience and time...
