ignition switch caught fire
Old May 25, 2010 | 08:07 PM
  #41
tk353's Avatar
tk353
Originally Posted by merdahl
TK,
Got the switch today and installed. Drop in replacement. Thanks for the link on that, you saved me $100. Now lets see what happens....
your welcome. how did you like those pictures?
Old May 26, 2010 | 12:24 AM
  #42
merdahl's Avatar
merdahl
I assume you are talking about all the "product shots" in the Ebay store. Yeh, I noticed and very nice. They are local and those pics almost made me pick up in person.
Old Jun 5, 2010 | 12:03 AM
  #43
idrivemywifecrazy's Avatar
idrivemywifecrazy
4th Gear
Default I had the same issue
I had the same thing happen to me about a year and a half ago with my 05 Heritage "Fire Fighter Edition" How ironic. I manage to breakdown "on" the door step of a Harley Dealer on a Sunday morning. Bought the Factory switch for...you guessed it....$100.00. Tore into the bike with minimal tools and was back on the road in about 3 hours. The crew at the Harley dealer was very helpful considering the shop was closed. When I enquired about the cause of such an issue, the head tech via a phone call, told me that the terminals start to vibrate loose causing arcing at the terminal. I thought that sounded reasonable but still questioned it. I got home and pulled my switch apart to install the original keyed cylinder, I noticed that the brass contact on the inside of the switch had melted about 1/16" into the switch case. Don't know if that means anything but it was odd to say the least. Good news is that I haven't had problems with it since.
Old Jun 29, 2010 | 08:14 PM
  #44
edeluxe07's Avatar
edeluxe07
I just experienced this exact same problem today...stuck in rush hour traffic on the interstate...bike died right in the lane and nowhere to go, no shoulder....lucky a DOT guy stopped for me and got me off the road without getting myself killed. In checking things out I had no blown fuses, but had no lights, ignition didnt' work, nothing...but I remembered this post, so I removed the console and sure enough the ignition contact terminal was burned right thru. I switched around the plug and therfore got power from the accessory side, and voilet!! the bike started! amazing... I too have a thundermax ECM, and you can bet, once I get a new switch and harness I'm yanking that thing off and putting my stock ecm back on and will decide what to do about tuning. My tmax also has the problem where the speedo will just lose contact with the ECM for no reason, and Zipper's has yet to find a fix for that.... I'm done with Tmax.
Old Jun 29, 2010 | 09:01 PM
  #45
tk353's Avatar
tk353
well if you sell the thundermax on the hd forums you will get about $450 delivered. i still run mine and for the little problem it has i am happy with it. are you getting the switch from ebay. good switch and much cheaper than Harley part.
I could not replace the plug so i got crimped connectors. i think i will solder them to the terminals before my trip to sturgis.
Old Jul 17, 2011 | 01:13 PM
  #46
kvwall's Avatar
kvwall
2nd Gear
Cool '03 Heritage Classic
Same thing just happened to me. I have the stock ECM. I broke down on the highway in West Texas on my way home to California. I was able to scrape enough crud off the connectors to get it fired up again. I got all the way to Las Vegas before it finally crapped out for good. The temperature was over 102 degrees every day on this trip.
The dealer in Vegas told me it was caused by connections getting loose. Fortunately I have family in Vegas to stay with. The bike is in the shop as I type and won't be ready for a week. They had to order an ignition switch that is keyed for my bike. (I wanted it that way) They also had to order a connector for the fuel pump because it was fried as well. (Yes, they showed me)
This will be my 3rd ignition switch! They seem to last me about 4 years. I have 54,000 miles on my bike now and keep it in the garage. It is well cared for. Harley needs to take some responsibility and make a better switch.
So here I am.... Stuck in Vegas and I don't even gamble.
Old Jul 17, 2011 | 07:05 PM
  #47
FroggyFatBoy's Avatar
FroggyFatBoy
from my experience whenever you see a electrical connector melted like that, it is due to a loose connection. the heat buildup from the arcing across the switch terminal to wire terminal is incredible and melts the plastic which in turn gets in between the the two terminals causing more resistance and more heat. eventually you end up with what the OP posted. its been happening for years in ford explorer blower motor switches/harness and honda has a recall on the ridgelines with their blower motor connectors coming loose and melting out the harness.
Old Jul 18, 2011 | 08:45 PM
  #48
Dissociative's Avatar
Dissociative
can i keep my key with the ebay one?..swap out the middle?
i don't want 4 keys
Old Nov 18, 2011 | 05:25 PM
  #49
kvwall's Avatar
kvwall
2nd Gear
Yes you can keep your key. I just swapped out mine. I found a youtube video that showed how to do it. Can't find it now but it was an easy swap. Now I just need to get a backup ebay switch to keep with me.
Old Nov 18, 2011 | 06:13 PM
  #50
wlbowers's Avatar
wlbowers
the replacement switch has a clean snap to it when turning on and off and the old switch has a soft feel. even the new bikes have a firm feel. bottom line is i fixed it my self for under $40
You got a bad switch then. Make sure the grips are tight in the new connector. Also make sure there is contact grease in it.
