Heritage Classic seat removal
Old Jul 16, 2006 | 01:13 AM
UltraBrian's Avatar
UltraBrian
Default Heritage Classic seat removal
I did some searching (maybe not enough), but I would like to remove the passenger pillion and go for the solo look. I loosened a total of 3 bolts; one behind the passenger pillion on the rear fender and 1 on either side of the main seat. I can't, for the life of me, get the seat off. Do I need to push down and back to unlock it or something? I've tried that, but it will not budge. Once I get it off, then I can take the 2 bolts off that hold the passenger pillion onto the underside of the main seat.
A little guidance from you guys will be appreciated.
Old Jul 16, 2006 | 01:21 AM
millzog's Avatar
millzog
Big Kahuna HDF Member
Default RE: Heritage Classic seat removal
Should slide back and off.................... at least it did on mine . Can`t see why it won`t for you ! Steve
Old Jul 16, 2006 | 01:22 AM
wildman67's Avatar
wildman67
If it's like my fatboy, you unscrew them and then you got to pull out on both side bolt's at the same time they are spring loaded.
Old Jul 16, 2006 | 01:23 AM
UltraBrian's Avatar
UltraBrian
Yea. After I unscrewed them, I noticed that they are spring loaded. Going to give it a shot now...be right back.
(Update) Got the seat/passenger pillion off. Now, guess I need a big torx wrench to get the strap off?
Old Jul 16, 2006 | 01:43 AM
wildman67's Avatar
wildman67
yup forgot about that!
Old Jul 16, 2006 | 01:45 AM
UltraBrian's Avatar
UltraBrian
CRAP!!! Seat with passenger pillion is going back on then. Don't have a torx wrench that size and don't want to try an Allen instead. Afraid I will strip it.
Old Jul 16, 2006 | 01:52 AM
wildman67's Avatar
wildman67
that one's a t-40. you can get thatone antwhere! like home depot and lowe's for a couple of buck's!
Old Jul 16, 2006 | 01:57 AM
Champion's Avatar
Champion
Just a thought here. I took the whole seat assemb. off my '03 Heritage Classic, the strape also, and had a hell of a time trying to put the strap bolts back later. I have changed the pillon for my wife now and instead of taking the strap off again I just cut the dam thing off with a sharpe blade. I cut close to the bolt and you cannot see it was ever there. Who needs the strape anyway. It is too tight to hang onto anyway.
Old Jul 16, 2006 | 02:37 AM
UltraBrian's Avatar
UltraBrian
Good idea, Champion. I want to take the pillon and put a fender bib on. Looks good imo. Will check out Home Depot/Lowes for the T-40. Thanks for the help/advice guys. Ride safe...
Old Jul 16, 2006 | 02:33 PM
Kid N8's Avatar
Kid N8
Hey Brian,
I've just taken that strap and folded it neatly and tucked it under the driver seat. It's not perfect, but it's good to ride.
