Engine drain plug stuck
Old Dec 24, 2009 | 01:12 PM
CrackOfDawn's Avatar
CrackOfDawn
Default Engine drain plug stuck
I can't get the drain plug out of an 02 1450 night train.
I already twisted an allen socket with a 16" breaker bar. WTF is going on here?
What are your thoughts on using an impact driver on it? I was just thinking about the case. Don't know if I really have another choice.
Old Dec 24, 2009 | 01:26 PM
tmitchellof PG's Avatar
tmitchellof PG
Was the bike up to operating temperatures? That might help and it should be when changing oil.
On my 2005 Fat Boy you can use an allen wrench or a socket. I always use a socket.
Are you sure you are trying to loosen the oil drain plug and not a freeze plug.
Tom
Old Dec 24, 2009 | 01:31 PM
mtairy biker's Avatar
mtairy biker
on a dresser it faces foward not down leave the down one alone
Old Dec 24, 2009 | 01:41 PM
CrackOfDawn
Tom
I'm pretty sure it is the oil drain plug, but if someone could chime in with the location of the engine oil drain, I can make sure before continuing.
The bike was not hot. Here's the deal. This is the bike from the "biker down.." thread. The jerk that picked up Bill's bike from the accident left it on its side and most of the oil drained out of the tank. I obviously could fill the tank and start it, then try. I just did not want to waste the oil.
That is what I told a buddy of mine I was going to do, and he said to be careful if it is that tight and you warm the engine up, the thread could come out with it. Since it is already that tight, he really did not think warming the bike was going to make a difference. If anything, he thought maybe getting it hot will expand everything, and thus possibly making it tighter.
Old Dec 24, 2009 | 01:42 PM
CrackOfDawn
Yeah, it is not the same layout as my sg.
Old Dec 24, 2009 | 01:49 PM
mtairy biker
yes it is a street glide is a dresser
Old Dec 24, 2009 | 02:01 PM
CrackOfDawn
Yeah, I know. I'm working on an 02 1450 night train. I did not realize I did not type that in my original question. Thanks for any help you can give.
Old Dec 24, 2009 | 02:06 PM
mtairy biker
it should be down by the swing arm on the right side facing down if i remember right
Old Dec 24, 2009 | 02:39 PM
DR.Greenthumb's Avatar
DR.Greenthumb
m tairy biker is correct.it's not on the bottom of the motor where you would think it would be.Leave that one alone
Old Dec 24, 2009 | 02:53 PM
CrackOfDawn
Ok guys, thanks. I'm pretty sure I was trying the correct one. I will recheck before proceeding.
Do the softtails have 3 drain holes? There is one right between the shocks on the bottom, and one on the primary side(left side), and then you are saying the other is on the right side back by the swing arm.
