Plastic hose into that last beer can you drank, get the bleeder loose, work the wrench with your left hand the brake with your right. I do it all the time, I just measured, it's 39" between the bleeder and pedal with 3" extensions, easily within 2 arm reach. Use a small piece of wood on the pedal if you need it.
Doug
Apehangers prevent me from manually bleeding the brakes...
The 40-100 bucks spent on a bleeder is well worth the money
Doug
I can, but why bother when it's so much simpler with the Speedbleeders. I can kickstart a bike too.
Great pics H&P... really helpful! is that the stock kickstand attached to the ness kit?
Yes, it is the stock kickstand. I had my rig installed by a professional because of the brake bleeding. No one has mentioned it but you also have to remove the exhaust as well.
I didn't have to remove the exhaust. What was yours in the way of?
