Help
Old Jan 1, 2010 | 06:45 PM
fclavijo's Avatar
fclavijo
Stage I
Default Help
Gentlemans, please help before i run of money, I am trying to cahnge the oil in my 2008 Softail Deluxe.
For the last 2 yrs Harley dealership has done the service, but I want to start working on the bike myself.
WHERE is the plugs for draining the oil?
in the store they told me it is 2 plugs but I am able to find only one
thanks
Old Jan 1, 2010 | 07:09 PM
Rakthi's Avatar
Rakthi
Check these links, come with pictures and step by step instructions.
Or buy the "fix my hog" DVDs
Or buy the service manual!
How to change primary oil:
http://www.dudeworld.com.au/HOWTO.PRIMARY.HTML
How to change engine oil:
http://www.dudeworld.com.au/HOWTO.ENGINE.HTML
How to change gearbox oil:
http://www.dudeworld.com.au/HOWTO.GEARBOX.HTML
Old Jan 1, 2010 | 07:13 PM
Nightking's Avatar
Nightking
DO NOT... I REPEAT... DO NOT remove the plug at the bottom of the engine case.The service manual would be a good investment if you want to do your own service work.
jimmers1817's Avatar
jimmers1817
Page 91 of your owners manual. Oil drain plug is in the frame rail on rt side of bike just below the passenger ft peg. 5/8 socket.
If you plan on doing service to your bike do yourself a favor and also buy a Service Manual part #99482-08.
Old Jan 1, 2010 | 07:24 PM
dennyo's Avatar
dennyo
look on the bottom of the Oil bag - tank, there will be a hose coming down
thats it
Old Jan 1, 2010 | 08:21 PM
krazy3's Avatar
krazy3
Make sure you can get the derby cover screws loose BEFORE draining the oil out of the primary. Don't ask me how I know.
Old Jan 1, 2010 | 09:39 PM
av8or's Avatar
av8or
What happens if you don't?
Old Jan 1, 2010 | 09:49 PM
Faast Ed's Avatar
Faast Ed
You won't be able to drive it to a shop to get the screws out, if the fluid is drained. I never found a screw I couldn't (eventually) get out, but those suckers can get froze in that cover and strip out the heads. Happens too often. (Dissimilar metals). The same mistake stranded my neighbor until I bailed him out with my chisel trick.
BKSinAZ
Oct 9, 2013 09:10 PM
Butts05Train
May 29, 2012 08:40 PM
Superglide Rob
Aug 14, 2010 06:34 PM
Ragnar Danneskjöld
Jul 5, 2010 07:40 PM
GoCubs
Sep 8, 2007 09:18 AM
