whats the best way?
Old Jan 7, 2010 | 06:02 PM
Greasemonkey1's Avatar
Greasemonkey1
Default whats the best way?
i think i need to take off the reflectos off my back fender and the forks, any suggestions on what works best, and how hard is it to install the lay down plate?
Old Jan 7, 2010 | 06:05 PM
TW's Avatar
TW
I use a hair dryer and some fishing line. You may also need a little Goo Gone to get the adhesive totally off.
Back when HD was putting them all on the front downtubes, I'd just use a hammer.
Old Jan 7, 2010 | 06:42 PM
Greasemonkey1
do that on the fender also?
Old Jan 7, 2010 | 07:24 PM
hpfatboy's Avatar
hpfatboy
Thumbs up
+1 on the fishing line, grab firm with both hands. And use back and forth motion like a saw, then use some solvent to take leftover adhesive off . NO ISSUES. For plate much easier to get back wheel off the ground so wheel can drop, giving you more room to work!
Old Jan 7, 2010 | 07:44 PM
skipper469's Avatar
skipper469
+1 more on the hairdryer and fishing line. When pulling the line through, keep it as close to the fender as possible, but I would only do one swipe as you can muck up your paint by doing multiple strokes. Use goo-gone until all residue is gone (might take a couple of times soaking and scrubbing with soft cotton cloth. It'll come out like they were never there and your paint unharmed.
Old Jan 7, 2010 | 08:16 PM
snip0721's Avatar
snip0721
+1 on the fishing line. dental floss works well too. +1 on lifting the bike for easier access to the rear plate. remove the seat and the black cover behind the battery. you can reach right back to the plate without laying on the floor. steve
Old Jan 7, 2010 | 09:20 PM
murlsquirl's Avatar
murlsquirl
Your bike is brand new so they will come off easy. They will probably just pull right off. I did mine when it was brand new and I pulled them right off and they barely left any adhesive.
Old Jan 7, 2010 | 10:44 PM
av8or's Avatar
av8or
I did mine when new as well. Started with a little heat and they came right off.
Old Jan 7, 2010 | 10:49 PM
oct1949's Avatar
oct1949
hair dryer and wd40
Old Jan 8, 2010 | 03:26 AM
FSAENZ's Avatar
FSAENZ
Sound easy.. I think I'll do mine when it warms up a bit.. I like the look
